Old 05-25-2009, 12:27 PM
stefunktrumpet stefunktrumpet is offline
Default CPU usage is holding off USB audio
hi,
i don't think that this behaviour is normal and in fact it is very annoying that's why i want to explain it to you. i hope you can help me:
my system:
Pro Tools LE 8
MBox 2
Mac Book Pro
2,4 Ghz Intel Core 2 Duo
4GB RAM
Mac OSX 10.5.7
I open a new session and create 3 instrument tracks:
1. RealGuitar 2L (VST wrapped) [latest driver]
2. BFD 2 [latest driver]
3. TL Metro
My Playback Engine Settings:
H/W Buffer Size: 2048 Samples
RTAS Processors: 2
CPU Usage Limit: 90%
DAE Playback Buffer Size: Level 4, Cache Size: Large
After I hit the play button it plays for about 10 seconds then it stops and i get this message:
"CPU usage is holding off USB audio. Remove some plug-ins, delete some tracks, or increase the H/W Buffer Size in the Playback Engine dialog (-6105)"
On one USB Connector there is only my MBox 2
On the other there is a Hub with my wireless mouse, my m-audio oxygen 49, my Keyboard, my VSL-Dongle and my Waves-Dongle.
On the Firewire-Connector there is my External WD "My Book".
I can't believe that this can't work.
Please help me.
Thank you very much
stefunktrumpet
Old 05-25-2009, 12:58 PM
Default Re: CPU usage is holding off USB audio
Couple of questions for you. Did it work on an earlier version of Leopard? Which USB port is the Mbox patched to? I think it should be the port farthest away from the screen. Have you tried it with the plugins not inserted?(I would at least see what happens starting with no plugins, then each one by itself, followed by each pair and see if you can blame any of the plugins(but try the USB port first if you are not on the one I talked about).
Old 05-25-2009, 01:30 PM
DigiTechSupt's Avatar
Also try reducing the number of processors dedicated to RTAS in the playback engine, as it's likely to help.
There are a lot more suggestions in the General Troubleshooting thread...
Avid Audio Tech Support
Support FAQ
Old 05-25-2009, 04:18 PM
thanx very much for your help.
in fact i just had to selct 1 processor instead of 2 and now it works just nice.
could you please explain to me why that is such a big difference
Old 07-05-2009, 04:59 PM
joematzzie joematzzie is offline
Yay, I had the same problem. I moved the USB from the monitor jack to the back of the tower, and changed CPU number from 4 to 1, and now it plays fine.
Thank you,
Joe
Original MBox
ProTools LE 7.4.2
Leopard 10.5.7
Mac Pro
Old 08-23-2009, 05:42 PM
DonM DonM is offline
Gordon:
Interesting thought .... but can anyone actually explain why 1 is better than 2? It does seem counter intuitive. Thanks in advance.
-D
Old 08-24-2009, 05:08 AM
Gordon:
I appreciate your 'colorful' assessment of the issue here. I'd equally appreciate a technical response.
-D
Old 08-24-2009, 10:07 AM
The Dougfather The Dougfather is offline
Ok, so in the playback engine you deditcate processors to RTAS, thats the RTAS plugins. So if you have both cores dedicated to RTAS there isn't much left for non real time code and everything else. By reducing to one dedicated RTAS core your opening up the CPU to do everything else it needs to do as well as keep RTAS processing running smoothly.
Pretty logical but not ideal, especially if you only have a dual core machine.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 08-24-2009, 06:26 PM
Doug:
Thanks for the response. I was doing some math in my head that pretty much assumed what you have said here.
I began wondering if this 'may' flip as the RTAS usage increases?
For example the load that I was seeing on my system never exceeded 12% but the engine halted. Might returning to 2 cores be suitable if the average load is 45% to 65%?
Thanks in advance for your insight.
-D
Old 09-20-2010, 05:30 PM
XsuspendedX XsuspendedX is offline
Hi, I've encountered a very similar error. It seems to me that I should normally not receive these because I had not prior to my 8.0.4 upgrade.
Im using a Digidesign Mbox Mini connected to an early 2009 MBP running 4g of ram and a core 2 duo @ 2.9
I've run through the multiple Hardware buffer sizes and switched between one or two cores with no resolve.
The issues seems to happen regardless of how many plugins or tracks I have in my session. I am using a few Waves plugins along side Reason and one or two of the DIGI eq's and comps.
I never had this issue with 8.0.3 any direction would be much appreciated, thanks!
CPU usage is holding off USB audio.... Dan Freeman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-23-2011 01:35 PM
CPU Usage Holding off USB audio help Nathan W. Pro Tools TDM Systems (Mac) 3 07-08-2010 03:21 PM
"CPU usage is holding off USB audio ... " MrBrown 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 11-12-2005 02:54 PM
cpu usage is holding off usb audio J-Mac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-29-2005 09:36 PM
CPU usage is holding off USB audio Whitecastle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 01-26-2003 09:34 AM
