Old 05-18-2009, 05:47 PM
AirborneFO AirborneFO is offline
Default Manual MIDI vs Keyboard Input
This is going to sound like a silly question and probably is. But I'll ask anyways (and yes, I am fairly new at this!) LOL
Anyways......I can get my nano Korg working with redrum no problem. The issue I run across is even if I am just a little off, I still have to go in and adjust the notes. I have also gone in and "penciled" in fills, grooves, etc. in redrum as well as having manually done it in PT.
Is there a better way of doing this? I especially find it really time consuming if I am doing a drum fill. Any tips?
Thanks!
Old 05-18-2009, 07:01 PM
Default Re: Manual MIDI vs Keyboard Input
Playing drum fills on a keyboard is the pits. I use an M-Audio Trigger Finger and find it works great, especially as it has 5 pages of pad assignments, which means I can devote 1 page to be setup for doing fills by assigning snare and toms to pairs of pads. With 2 pads for each drum sound, you can really play fills 100 times better than trying to whack a single key or pad. Without that, the pencil method will likely get the best results. One thing I have done(with the Trigger Finger) is advance past the end of the song and just record fills(to a click). By recording a bunch of variations, you can copy/paste into the song. Quantize will be your friend no matter what you use. I also have a Roland TD kit but I can play fills on the TF almost as well(except for the kick).
Old 05-18-2009, 11:03 PM
flommer flommer is offline
If you are talking about the Korg NanoPad, then you can do something similar to what albee is describing on the trigger finger....
There is a configuration editor for the nanopad that you DL from korg and it allows you to assign the notes to the pads as you want, and there are 4 scenes so you can set up 1 scene to have the dual hats or snares or toms, etc...
The editor is caller KORG KONTROL editor...
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 05-19-2009, 11:12 AM
I brought to Iraq a nano Korg keyboard. I got a brand spankin new Akia MPK49 before I left, so at least it gives me something to look forward to. I kinda figured penciling in track, cut/paste, etc was probably the answer. I have done different fills at the end and am able to tweak a little which does help.
MIDI Input from keyboard, lag before hearing sound danjfoley Windows 3 01-13-2014 01:55 PM
MIDI input via computer keyboard. vinylrider macOS 1 05-31-2013 07:27 AM
MIDI input via computer keyboard. vinylrider macOS 0 05-31-2013 07:15 AM
Keyboard midi input not recognized rthomas73 MIDI 2 03-31-2011 03:27 PM
Using your computer keyboard as input for MIDI PaulG1522 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-03-2007 02:09 PM
