Community Terms of Use
Google Search | Search Knowledge Base | Search Avid.com
Find Support | Pro Tools Support Videos | Support FAQ
Software Updates, Drivers, Manuals, Compatibility, Troubleshooting, etc. (Links)
Please post your message once only to the correct forum
Help us Help You - READ THIS Before Posting!
Pro Tools 11
Old 05-16-2009, 09:24 AM
Albinorican Albinorican is offline
Default Please help, using NI Traktor with Mbox 2 Pro
Hello,
Anybody else here that is using Traktor with Mbox?
How do I route etc to be able to queue in my headphones using Mbox Pro and Traktor? Right now, I just hear the track thats coming out of the speakers, I'm not able to hear the track on the other deck that I want to mix in. My headphones are plugged into the Mbox Pro.
And one more question, do You know how I can use my microphone thats plugged in to my Mbox Pro with a software compressor on if that is possible during recording a DJ-set?
Would be really really thankful if somebody could shed some light on this for me.
Best Regards
-Alex
Old 05-20-2009, 03:37 PM
astronout astronout is offline
Default Re: Please help, using NI Traktor with Mbox 2 Pro
Hi Alex,
I use this setup. Took me a while to figure it out but his is how I do it.
You’ll want to plug your headphones into the 2nd head phone jack and press the “3-4” button. This will allow you to monitor your cue mix via the headphones on outputs 3-4. In Traktor’s Output Routing preferences, you’ll want to set the Monitor to Outputs 3 and 4. The headphone cue mix is controlled by the ‘Ph Mix’ knob in traktors UI. Move it to 0% and you’ll hear whatever is cued. Move it to 100% and you’ll hear the Master out. Move it anywhere in between and you’ll hear a mix of both.
Hope this helps!
-Mark
Old 05-22-2009, 10:32 AM
Hi Mark!
Thanks alot, I'm gonna try this, It will probably work!
I will let You know, thanks again!
Old 05-22-2009, 11:34 AM
Thanks Mark! It worked, first It didn't, but I had forgot to press down the Cue button haha, I sat for 20-30 minutes trying to figure out what it was, Embarressing considering that I've been a DJ for 15 years..
Old 05-22-2009, 11:39 AM
By the way, How do You record a set?
Whats the routing and procedure? Would be great if You could help me with that also.
Old 05-22-2009, 12:57 PM
Hey,
Glad it worked! :)
When I record a set I route the MBox SPDIF out to an Alesis Masterlink recorder. I'll then bring the audio back into Pro Tools if I need to make any edits.
-m
Mbox 1 + Traktor Scratch habitats Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac) 2 11-25-2010 11:11 AM
Traktor DragonBlight General Discussion 0 03-31-2010 01:58 PM
Mbox & Traktor (audio 8) issues with feedback Sebastian C. Pro Tools M-Powered (Mac) 0 11-08-2009 08:42 AM
routing Traktor using Digi 002? tritonkorg Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) 0 01-16-2007 02:53 PM
Mbox 2 Pro vs Mbox latency - Mbox 2 Mini pro? marcnyc Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac) 1 11-28-2006 07:18 PM
