Old 05-14-2009, 08:42 PM
elsterNJ elsterNJ is offline
Default Error: "pro tools could not complete the import audio command because assertion in"
Getting this when trying to import an aiff into my session. Pro tools 8. Mbox 2 on Windows. Any ideas?
Old 05-15-2009, 09:00 AM
sw rec sw rec is offline
Default Re: Error: "pro tools could not complete the import audio command because assertion i
Not without some actual information. What's the error number?
Please post a system report:
http://duc.digidesign.com/showthread.php?t=193637
What version of Windows?
Old 05-15-2009, 09:38 AM
DigiTechSupt's Avatar
Per the info in the General Troubleshooting thread, random assertion errors are usually due to a corrupted database and trashing them will typically fix it.
Avid Audio Tech Support
Support FAQ
Does "Automatically Copy Files on Import" work with Import Audio command? leftalive Pro Tools 10 3 04-17-2013 09:35 PM
Could not complete the Open Session..command Assertion "KeyContextRegistry" line72 JLiRD808 Windows 4 12-25-2012 01:01 PM
FIXED: Startup issue: "Could not complete request because Assertion line 1424" wheret Windows 2 07-11-2012 05:43 PM
"Could not complete the import audio command because DAE error 35 was encountered..." Sean_tiburon macOS 1 02-29-2012 07:03 AM
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... tohmit macOS 5 03-23-2011 12:13 PM
