Old 05-12-2009, 03:30 AM
scottthafoo scottthafoo is offline
Unhappy THE APPLICATION FAILED TO INITIALIZE PROPERLY (Oxc0000005)
I recently got a whole bunch of VSt's from my producer friend and all of a sudden Pro Tools won't start. I click on the Pro Tools LE icon and I get the windows prompt of:
Pro Tools Application has Stopped Working
If I click view problem details I get this...
Problem Details
Problem signature:
Problem Event Name: APPCRASH
Application Name: ProToolsLE.exe
Application Version: 7.4.0.309
Application Timestamp: 472841cc
Fault Module Name: ntdll.dll
Fault Module Version: 6.0.6001.18000
Fault Module Timestamp: 4791a7a6
Exception Code: c0000005
Exception Offset: 00043387
OS Version: 6.0.6001.2.1.0.256.1
Locale ID: 1033
Additional Information 1: e51a
Additional Information 2: 4c0d4d78887f76d971d5d00f1f20a433
Additional Information 3: e51a
Additional Information 4: 4c0d4d78887f76d971d5d00f1f20a433
Then I chose the option to:
CHECK ONLINE FOR A SOLUTION AND CLOSE THE PROGRAM
Then I get a error message saying
THE APPLICATION FAILED TO INITIALIZE PROPERLY (Oxc0000005). CLICK OK TO TERMINATE THE APPLICATION.
My first reaction was to erase all the VST's and reinstall Pro Tools so that exactly what I did. Still didn't work. I then thought maybe I had a virus so I ran a full scan of Mcafee, Spybot, Adaware, regcure... and Malware remover. Nothing.
I then tried to run pro tools in safe mode and it fires up fine! all the way up to where it needs the M-Box 2. (in safe mode driver doesnt load, obviously) I recently installed Microsoft 2007, could that be it??? Any help in any direction will be great. Thanks !
I'm running
Windows Vista Ultimate 32-Bit
Pro Tools Le 7.4
M-Box 2
Old 05-12-2009, 03:41 AM
TOM@METRO's Avatar
Default Re: THE APPLICATION FAILED TO INITIALIZE PROPERLY (Oxc0000005)
Is it possible that any of the acquired plug-ins were not properly authorized? This can cause nightmares with Pro Tools.
Are you using the VST wrapper? What version? Are any of these RTAS plug-ins?
~ tom thomas
Formerly hobotom
Pro Tools HDX~HDN 2018.4
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 05-12-2009, 01:40 PM
Yeah I use my roland fantom xr and mpc all in FL STUDIO 8 then I add vst's using fruity wrapper. Everytime there was a RTAS option i selected no. But where can I check what RTAS's are installed?
Old 05-12-2009, 03:04 PM
chazc080488 chazc080488 is offline
Did u install internet explorer 8. if so uninstall it!
Old 05-12-2009, 09:21 PM
Thumbs up Re: THE APPLICATION FAILED TO INITIALIZE PROPERLY (Oxc0000005)
THANK U SO MUCH!!! THATS ALL IT WAS! I would of never guessed that...thanks a million...
Old 09-08-2009, 08:41 AM
syo66 syo66 is offline
Thank you and thank you!!!
If only Microsoft were half as sharp as some of the people on the DUC...
Old 09-08-2009, 10:53 AM
The Weed's Avatar
The Weed The Weed is offline
Actually, it's supposed to be a PACE problem with IE8, not really a Microsoft issue.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 09-17-2009, 02:21 AM
phoniclynx phoniclynx is offline
Question .... WHY... hasn't digidesign found a work around and repaired this problem thus far? Most people including me use IE8 every day...
Old 09-17-2009, 05:01 AM
sunburst79 sunburst79 is offline
Apparently its a multipart issue needing updates from both PACE and AIR regarding the plugs in question. In another thread DTS mentioned that a fix was in the works.
You might find this thread interesting along with a link to a workaround from DTS in post #7.
I haven't tried this personally yet.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
HELP I'M IN DRIVER HELL! "The application failed to initialize properly (0xc0000005). gerry c Pro Tools Software (Win) 8 01-06-2014 08:22 AM
Pro Tools 7.4 failed to initialize properly(Oxc0000142) Kentjm Pro Tools 10 2 07-13-2012 03:49 PM
Keep getting "application failed to initialize properly 0xc0000005" georgeearth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-23-2011 08:16 AM
application failed to initialize properly (0xc000001d or 0xc0000142) graveleye Pro Tools M-Powered (Win) 4 04-12-2011 05:58 PM
Program failed to initialize properly (0x80000003) JonHallur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-12-2009 05:40 PM
