Avid Pro Audio Community |
hey,
i just bought an Mbox 2 mini, but i am unable to install the drivers and pro tools do to an error massage every time. i am starting to think i have been givin a faulty DVD. this being the error Feature: Application Files Component: Digi Audio Drivers File: F:\Protoo~6\data2.cab Error: Data error (cyclic Rendundancy Check) this happens everytime at around 10/15% is this a known issue? witch there maybe an solution to? or should i just ask for a new DVD at the place i purchased it? thanks in advance (if this is in the wrong section sorry for that, new here:) |
It's highly possible that you need a firmware update of your Optical drive, but without more details of your system, it's really hard to say.
Instructions for posting info are in the General Troubleshooting post.
My Website: Pro Tools "Newbie" Help New studio rig: Gigabyte GA-EX58-UD3R, Intel i7 920, 6GB Patriot DDR3. ASUS EN7600GT, LG GGW-H20L BD-RE, Sony CRX195E1 CD-RW, 2x ICY DOCK MB671SK-B (trayless hotswap), 2x WD Caviar black 640GB (os swap), 1x WD caviar 320GB (sessions), 1x Maxtor 120GB (sessions), 1x Seagate 1TB (samples/loops) |
hey, srry for that:)
here is some of my PC speccs (SiSoftware Sandra used) as said i am quite new to all this, but i hardly think my speccs are the problem, since i cant pass the install do to an error. tho ill look into your tip thanks for that:) and yes ill upgrade my RAM in the near future ![]() SiSoftware Sandra System Workgroup : MSHOME Processor Model : Intel(R) Core(TM)2 Duo CPU E6750 @ 2.66GHz Speed : 2.68GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing System System : System manufacturer System Product Name Mainboard : ASUSTeK Computer INC. P5KPL-CM Bus(es) : ISA PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes BIOS : American Megatrends Inc. 0512 Total Memory : 2GB DIMM DDR2 Chipset Model : ASUS P35/G33/G31 Processor to I/O Controller Front Side Bus Speed : 4x 335MHz (1.34GHz) Total Memory : 2GB DIMM DDR2 Memory Bus Speed : 2x 402MHz (804MHz) Memory Module(s) Memory Module : Corsair CM2X1024-6400C5DHX 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module : Corsair CM2X1024-6400C5DHX 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Video System Adapter : NVIDIA GeForce 7950 GT (24 PS3.0, 8 VS3.0 570MHz, 256MB 2x702MHz, PCIe 1.00 x16) Storage Devices MAXTOR STM3250310AS 250GB (SATA150, NCQ, 8MB Cache) : 233GB (C:) (D:) (E:) ATAPI DVD A DH20A3P (ATA66, DVD+-RW, CD-RW, 2MB Cache) : 8GB (F:) Logical Storage Devices Hard Disk (E:) : 98GB (NTFS) @ MAXTOR STM3250310AS 250GB (SATA150, NCQ, 8MB Cache) Hard Disk (D:) : 98GB (NTFS) @ MAXTOR STM3250310AS 250GB (SATA150, NCQ, 8MB Cache) Hard Disk (C:) : 38GB (NTFS) @ MAXTOR STM3250310AS 250GB (SATA150, NCQ, 8MB Cache) Pro Tools LE (F:) : 8GB (CDFS) @ ATAPI DVD A DH20A3P (ATA66, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS 82801GB/GR (ICH7) LPC Interface Controller Audio Device : ASUS 82801G (ICH7) High Definition Audio Audio Codec : VIA VT1708B 8-channel High Definition Audio CODEC Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : ASUS 82801G (ICH7) Ultra ATA Storage Controller Disk Controller : ASUS 82801GB/GR/GH (ICH7) Serial ATA Storage Controller USB Controller 1 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 2 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 3 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 4 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 5 : ASUS 82801G (ICH7) USB 2.0 Enhanced Host Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Network Services Network Adapter : Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller - Packet Scheduler Miniport (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Home 5.01.2600 (Service Pack 3) Platform Compliance : x86 Performance Tips Tip 2546 : Large memory modules should be ECC/Parity. |
The G33 and G31 are known to be problematic with Pro Tools. According to the information I found, the P5KPL-CM actually uses the G31, so that would definitely be a problem. Also, the motherboard you are using has built in Graphics, though it appears you aren't using them. Built in graphics are always a problem for Pro Tools, and are not supported. Make sure you have them disabled in the BIOS (which it looks like you do). Sometimes the built in graphics can be a problem even if you have them disabled. Quote:
I also see that you have your system disk partitioned, but you have no other hard drives present. Be aware that while that is not causing your current problem, Pro Tools requires a separate physical drive for audio sessions. Running from a partition on the system drive does not qualify.
if your getting a CRC error, id say you could have a faulty disc. Thought it would be unlikely, but a cycle redundency check error means theres an error trying to read/write the data. Speak to tech support.
good luck
Windows 7 Pro 64-bit Intel Core i7-2600K @4.5GHz QUAD 8 MEG CACHE W/HT LGA1155 Motherboard dual channel DDR3 TI firewire (Sandy Bridge) Mushkin DDR3 16G RAM Pro Tools HD Native 9.0.5 C24 Eleven Rack Lynx Aurora, LTHD UAD2 Quad Neve ----------------------------------------------------------------- MacBook Pro 2.3GHz Quad-core Intel Core i7 8GB 1333MHz DDR3 SDRAM Pro Tools LE 8 Glyph Tech GT050Q 003 Rack Mbox2 mini |
Could also be that your DVD drive is toast.
true but im sure he's tried another disc.
Copy the files to a thumb drive on a different machine and then drag the files to your desktop and run the installer.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
I'm not getting the data error as Menulo. However, I just purchased the 003 Rack Factory and PT 8 will not install on my desktop. It takes about 1.5hrs. and the only thing installed is part of the digidesign audio driver (file size is about 2.58mb at that time but I think the drivers are much larger though I can't say for sure). The dvd is installing very slow. Other programs do not function like this when installed on this pc.
Digidesign tech support gave me a link for the PT8 dload but it displayed 14hrs of dload time with a dsl connection (only enabled the ethernet and connected to internet to dload this). I gave up after 45mins. with the remaining time still displayed @ 13hrs. I previously ran PT 7.4 with the M-Audio Pro-Mix I/O until the pro-mix suddenly quit on my. My desktop is optimized and I never had any problems before. Anyone else having problems with the PT8 dvd installing (installing extremely slow)? |
Mixxmann it sounds like there is an inherent problem with your computer to begin with if it wants to take 14 hours to download that file. Are you sure that you completely uninstalled 7.4? Older plugins might be the culprit as well. As it has been previously pointed out, Internet Explorer 8 can cause problems loading windows. So many possibilities. You might want to post a Sandra report just to help trouble shoot.
Phenom 965 x 4 @3700MHz ASUS M3A76-CM 4 Gig PC6400 1 x 120 Gig Corsair SSD 2 x 160Gig Seagate HDD 1 x 320Gig Seagate HDD 1 x 500Gig Seagate HDD UAD-2 Solo Presonus Firestudio Mobile KRK RP5 Windows 7 Pro. 64 bit Sonar X2 Samplitude 11 Producer Sampletank 2 XL EZDrummer Guitar Rig 4 ProTools 9.06 All legit software thank you very much. Yes I have a low post count but only because I don't have a lot of problems with my gear. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Pro Tools 9 error message with Mbox mini | jetsjetsjets | Pro Tools Software (Mac) | 2 | 01-18-2012 05:58 PM |
| Strange install problem MBOX 2 Mini + Pro Tools LE | amarucci777 | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) | 3 | 04-26-2010 12:47 PM |
| 003 and Mbox 2 Mini - Do I Need to Install Pro Tools LE Twice? | Timmus | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) | 4 | 01-28-2010 06:41 PM |
| 003 and Mbox 2 Mini - Do I Need to Install Pro Tools LE Twice? | Timmus | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac) | 3 | 01-28-2010 02:42 PM |
| Can't get Windows XP to install Mbox Mini for Pro Tools 8 installation | jacobmoon | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) | 1 | 08-05-2009 07:22 PM |
