Community Terms of Use
Google Search | Search Knowledge Base | Search Avid.com
Find Support | Pro Tools Support Videos | Support FAQ
Software Updates, Drivers, Manuals, Compatibility, Troubleshooting, etc. (Links)
Please post your message once only to the correct forum
Help us Help You - READ THIS Before Posting!
Pro Tools 11
Old 05-05-2002, 12:16 AM
MilesMusic MilesMusic is offline
Default Locking audio to Bar/beat grid
I know this has been discussed before, but I was wondering if there was any new info on this topic.
I need to be able to lock audio regions to bar/beat grids. This is easily do-able in DP or StudioVision (R.I.P.) and a fairly important tool for composers needing to change tempos after laying audio chunks (percussive hits, etc.) into a sequence.
Is this possible in ProTools or do we have to wait for a revision for these kind of real MIDI sequnceing tools (like notaion editing)?
I actually like using PT for sequncing and have stopped using DP after 12 years. When it comes to long cues with complicated tempo maps, I have to go back to DP. Clients and directors like to tweak music too much. THis requires much flexiblity with tempos...
Old 05-05-2002, 02:08 AM
DigiTechSupt's Avatar
Default Re: Locking audio to Bar/beat grid
There is no preference to make regions automatically lock to the grid (when the session tempo is changed), but you can achieve this by utilizing Beat Detective.
I am not in front of Pro Tools right now, so this is from memory:
1. In bars/beats grid mode, highlight a selection of bars on the track(s) that you want to conform to a different tempo.
2. Make a note of the bar/beat that your selection starts and ends on, e.g. Start: 12|1|000, End 25|1|000.
3. Create a memory location for the selection. Set the memory location type to Selection (not Marker), and the reference to Absolute (not Bars|Beats).
4. Change the tempo of your session as desired.
5. Recall the memory location selection you created in step 3.
6. Open Beat Detective.
7. In the Selection field of Beat Detective, enter the bar/beat start and end times you made a note of in step 2.
8. Go to the Conform window of Beat Detective, check the Strength box, and set the strength to 100%.
9. Hit the Conform Button. You will get a dialog box asking if you want the regions to conform to the new tempo; click yes (I do not remember the exact wording). Your regions will snap to the grid of the new tempo.
Hope that helps.
Steve
Avid Audio Tech Support
Support FAQ
Pro Tools 11 FAQ
Old 05-07-2002, 09:47 AM
Thanks Steve.
Unfortunately, your solution is not 100% accurate. When working with long cues (2 minutes and longer), changing tempos can radically alter the grid forcing me to manually move audio to the correct bar/beat marker (especially if working on an 1/8th note grid or smaller)
This is a one click operation on all other sequencers that I know of. IMO, if PT is going to compete as a pro MIDI sequencer, locking to the bar/beat grid is essential. Notation editing, or more importantly, music part printing is a close second.
Old 05-07-2002, 10:24 AM
Originally posted by MilesMusic:
Unfortunately, your solution is not 100% accurate. When working with long cues (2 minutes and longer), changing tempos can radically alter the grid forcing me to manually move audio to the correct bar/beat marker (especially if working on an 1/8th note grid or smaller).
<font size="2" face="Verdana, Arial">I am not sure why this is not working for you. I just created a session with a 16th note grid and a couple of cues including a 2 minute cue, and the method I described above worked perfectly for snapping the regions to the grid (I had changed the tempo from 120 bpm to 139 bpm).
<font size="2" face="Verdana, Arial">That's definitely a valid feature request.
Steve
Support FAQ
Pro Tools 11 FAQ
Old 05-07-2002, 01:31 PM
Robert U Robert U is offline
I totally agree with Miles. That function would make my life so much easier!
-Robert
www.extensivemusic.com
Audio Recorded from MIDI track ahead of the beat/grid CalebB Pro Tools Software (Mac) 1 10-22-2012 10:03 PM
Grid and Bar/Beat Markers scrambled and disabled after using Beat Detective!! Robbry Pro Tools M-Powered (Win) 0 02-24-2010 01:14 PM
what do grid lines do after beat detective bar-beat markers cc1 Pro Tools TDM Systems (Mac) 1 05-22-2007 08:34 AM
locking regions to grid Aussie Scott Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) 8 03-25-2006 12:03 AM
locking midi to grid jackruston MIDI 13 08-10-2002 05:26 PM
