Old 04-22-2002, 04:27 PM
DrC:drive DrC:drive is offline
Default Problem with Transport counter jitters
I am having a problem with the transport counter display, it is not rolling smoothly but seems to pause for a moment every few beats as does the scroll cursor, and then restart as if its stalling temporarily. It is cured by reinstalling PT but then recurs again spontaneously. Its quite annoying since the scrolling cursor pauses as well and its difficult to see where you are in the track.
Mac G4 350mhz, 704 MB RAM, os 9.04, PT 5.1.1, Control 24
Anysuggestions how this might be fixed
Cheers
James Cullen
Nimrod Audio
Old 04-22-2002, 04:31 PM
Jan Folkson Jan Folkson is offline
Default Re: Problem with Transport counter jitters
Having a Direct-Connect plug in enabled without it's corresponding application opened will cause this.
- Jan Folkson
www.janfolkson.com
Old 04-22-2002, 04:46 PM
letrev's Avatar
letrev letrev is offline
This can also be caused by a CPU drain or inadequate memory buffer settings. If you have a ton of RTAS plugs running, try taking a few out or switch them to TDM.
Steven Vertel
Mixing / Mastering Engineer
High Rock Records & Studio
NYC
http://highrockrecords.com
Odd counter/transport behavior TheHopiWay Pro Tools TDM Systems (Mac) 0 02-20-2010 08:30 AM
Main counter mode not switching using "counter" switch bashville ICON & C|24 2 08-07-2009 04:07 PM
transport/counter/clock behaving strangely hydrophilos Pro Tools TDM Systems (Mac) 1 08-03-2009 05:59 PM
Pro Tools 7 transport counter & Mix LEDS freezes!! lenny ace 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-02-2007 10:40 PM
HELP!!! Bizzare click track/counter problem oneson2k 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-16-2005 07:45 AM
