Old 03-31-2009, 12:34 AM
the 5cientist the 5cientist is offline
Default Digi 002 M-Audio Octane ADAT clock problem!
Hey guys,
I'm a real novice at this stuff, but I got a small little setup, of an M-Audio Octane Pre into my 002 Console.
I got real excited at the prospect of using ADAT to connect the 2 units, so i got my lightpipe cable, and went to record.
I started to get clicks and pops out of the ADAT, and i've since realised that this is a problem with the clock between the 2 units. (still trying to work out what the clock is but anyway...)
When i get to Setups>Hardware Setup... To sync the 002 clock with the OCTANE, in ProTools 6.4 I get the message that 'There are no Digidesign Cards in the System'. I can't work out what that means, or any other way around it?
How do i sync the clocks so that i can use my mic pre?
Thankyou so much for anyhelp you can give!
Will
http://www.willudall.com
Old 03-31-2009, 06:09 AM
Third Eye Studios Third Eye Studios is offline
Default Re: Digi 002 M-Audio Octane ADAT clock problem!
Set the clock on the 002 to ADAT. Make sure your session and adat preamp are set to the same sample rate.
Third Eye Studios.org
Old 03-31-2009, 08:32 PM
Thanks Third Eye, but the only way that i can find to set the clock on the 002, is in the Setups>Hardware. HOWEVER, as mentioned in my original post, and highlighted below, Hardware Setup is blocked for me, with an error message:
How can i get around this error, to then be able to set the clock to ADAT?
Thanks,
Will
work clock sync 003/RME Fireface/M-AUDIO octane b mcgibney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-08-2008 11:29 PM
Newbie: Get no signal from M-Audio Octane via ADAT Braveheart 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-17-2008 09:06 PM
Digi 002 R problem detected with audio clock. HELP :( thexflamesxburn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 06-11-2007 11:10 AM
problem detected with audio clock Digi 002 rack Ben83 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-13-2006 10:35 PM
M-audio Octane, and ADAT (toslink?) w/CoreAudio KamaSutra77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-22-2005 10:59 AM
