Community Terms of Use
Google Search | Search Knowledge Base | Search Avid.com
Find Support | Pro Tools Support Videos | Support FAQ
Software Updates, Drivers, Manuals, Compatibility, Troubleshooting, etc. (Links)
Please post your message once only to the correct forum
Help us Help You - READ THIS Before Posting!
Pro Tools 11
Old 03-13-2009, 10:36 AM
tommydigiowen tommydigiowen is offline
Default BASIC BOOM Question.. Please Help.
Okay; I feel like an idiot for asking but how do I get these Boom samples into my timeline? I'v tried everything from creating stereo midi tracks, audio tracks and recording but its not grabbing anything from Boom.......
There are probably some very basic steps I'm overlooking because I'm having the same issue with the new Grand Piano plugin but any help would be greatly appreciated.
Thankyou!
Tommy
Old 03-13-2009, 10:38 AM
audiogeekzine audiogeekzine is offline
Default Re: BASIC BOOM Question.. Please Help.
Make a stereo instrument track
insert Boom (or any other instrument) in Insert Slot A
With boom patterns are mapped to one part of the keyboard, and individual drums are on another.
@theaudiogeek
| www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com |
Old 03-13-2009, 11:09 AM
I don't guess I understand what you mean by mapping to parts of the keyboard........ Can I click & drag the grooves over to the instrument track or are there some other inputs/outputs I need to setup?
Thanks alot
T
Old 03-13-2009, 11:15 AM
no, just play a C1 (for example) to play pattern 1. C3 (?) to play the kick drum only.
It's MIDI
@theaudiogeek
Old 03-13-2009, 11:25 AM
You would need to Bus Record the Boom pattern sequence.
*Stereo Instrument track, Insert Boom
*Instrument Track Audio Output>assign Bus 1-2
*Create a Stereo Audio Track and assign the Input to Bus 1-2
*Record Enable the Audio Track and Record.
This will record Boom to the Pro Tools Timeline in Audio.
filosofem
Old 03-13-2009, 11:40 AM
Perfect man..... Thanks alot!
T
Old 01-29-2010, 09:35 PM
johnmark58 johnmark58 is offline
That was very helpful for me, too. Thanks so much!
jOHn
Old 07-23-2010, 10:57 PM
polmedi polmedi is offline
And if you want to record the Boom in a midi track?
Old 07-24-2010, 06:25 AM
PT Lover's Avatar
PT Lover PT Lover is offline
Instrument tracks are basically an aux and a MIDI track combined into one. Since Boom outputs audio it's best to use Instrument tracks IMO.
Stig Eliassen
Master: PT 7.4.2 HD3 Accel | Dual 2.3 G5 w/4.5GB RAM | 10.5.8 | 192 I/O | D-Command ES
Slave: PT HD 10.3.5 | Eleven Rack | VE Pro 5 | 6-core 3.33 Westmere w/24GB RAM | 10.6.8
Mobile: PT 10.3.5 | Eleven Rack | iMac 12,1 w/12GB RAM | 10.8.2
Old 09-06-2010, 08:10 AM
manonash manonash is offline
filosofem
I thought sure this was going to solve my problem, and apparently is has solved others' problem -- but when I do this I get no audio on the Audio track. The Instrument track volume meter shows the drum kit banging away, the Instrument track output is set to Bus1-2, the Audio track input is set to Bus1-2, and the Audio track output is set to Output1-2. But I get zilch.
Anybody have an idea?
Thanks!
(ProTools 8.03)
Question on Boom DonaldM Virtual Instruments 4 05-18-2011 01:17 AM
Boom question manyrains Virtual Instruments 1 10-20-2010 07:15 PM
BOOM Question mrmosquito Virtual Instruments 8 09-30-2010 06:22 PM
Basic, basic recording question enigami MIDI 1 06-08-2009 05:27 PM
Basic Pro Tools use. Really Basic question. Shizznik_McRuube Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) 1 09-14-2002 10:41 AM
