Avid Pro Audio CommunityHow to Join & Post • Community Terms of Use • Help Us Help YouKnowledge Base Search • Community Search • Additional Resources |
I am having an unnerving problem... This just started happening with Pro Tools 8, and I don't want to go back.
I am using a late 2008 (intel) iMac, Mac OSX 10.5.6, and have used Pro Tools 7.4, 7.4.2, and now PT8.0. I have an Mbox Mini, plugged into an external Hub, as well as using a firewire 400 HD. This problem started in 7.4.2 and has now carried over, (and quite possibly intensified) with Pro Tools 8. It used to happen intermittently, the audio would have a static distorted quality for 5-10 seconds. Usually it sounded like radio static, almost like the static was only prevalent when audio was actually playing. (not constant in the background) When a voice would talk, you could hear the static react to the words. I figured it was an issue with the Mbox, possibly the hard drive. I could handle that, because it was once in a long while. It didn't happen often, and only for a few seconds. But now with Pro Tools 8, the problem seems much worse. Same symptoms, but almost 90-100% of the time during audio playback. It starts off normal, and then after 5 seconds of normal sounding audio, static and distortion. Very light, again almost like crappy TV reception, or bad radio antenna. I don't know what to do... help |
DID YOU DO THE CS1 UPDATE? I had a number of issues with 8.0 multiple crashes buffer errors in addition to the MBox static, ever since the cs1 update I've been trouble free, maybe you should give it a try.
![]() Quote:
Mbox Mini 3G Playback Distortion | norwenna | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-18-2013 03:01 PM |
MBox 3rd Gen Mini making static/distortion/feedback during vocal recording | Duckett | Pro Tools 9 | 1 | 01-09-2013 09:11 PM |
Mbox Mini - Intermittent Distortion during Playback | bilco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 02-13-2012 05:55 AM |
Distortion and Static during playback in Pro Tools 8.0.1cs1.. | Teej of The Teamsterz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-06-2010 02:52 PM |
Pro Tools 8 Distortion Static Pop on playback and bounce | MediaLocal.com | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 05-07-2009 02:32 PM |
