Old 02-18-2009, 04:54 AM
paulrgmusic paulrgmusic is offline
Question Pitch Bend range
Hi
Can anyone tell me how to increase the pitch bend range in Pro Tools?
I am trying to create a big comedy trombone slide using Xpand but can only bend +/- 2 semitones.
Please help, it's driving me mad!!!!!
Paul
Old 02-18-2009, 10:51 AM
SeedGuy SeedGuy is offline
Default Re: Pitch Bend range
The pitchbend range is set within the VI, and each VI can have it's own independent settings.
There may be a setting within Xpand itself, if not, which I can't recall off the top of my head, then Xpand must have a set range of 2 semitones.
Old 02-18-2009, 11:26 AM
flommer flommer is offline
I was looking at this recently and I don't think Xpand allows the pitch bend range to be adjusted.
If you got Sampletank2SE with your bundled apps, that has pitch bend.
Structure Free does too...
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 02-18-2009, 05:41 PM
Correct!
This is covered in the Xpand! Plug-In Guide.
filosofem
Old 02-19-2009, 04:21 AM
Thanks for the replies
Filosofem - I did actually read the manual but it made no sense to me (I didn't know whether your response was a RTFM post or not!). It was full of unfamiliar acronyms and code like cc101=64, cc6=no. of semitones (or something similar). When I tried to find these values within Xpand 2 I couldn't. Then I wondered if this function had been removed in Xpand 2 as the manual is for the original Xpand. It would appear that there is no manual for v2.
Paul
Old 02-20-2009, 04:36 PM
Hi Paul
Pitch Bend (PB Range) is defined in the Xpand!2 Chapter of the Creative Collection Guide.
Xpand!2 PB Range is far more user friendly than that of the original Xpand! (version 1.0) as Registered Parameters (RPNs) needed to be used. CC100 (LSB) and CC101 (MSB) needs to be sent together followed by CC06 (Data Slider) that defines Pitch Bend Range in semitones.
filosofem
Change pitch wheel bend range in Midi event operations phair 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-24-2018 08:21 PM
Pitch bend manley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 05-07-2009 08:34 AM
pitch bend range in Xpand! bassntreble Virtual Instruments 4 06-20-2006 02:56 PM
Change Pitch Bend Range in Xpand! JohnLochner Virtual Instruments 0 04-06-2006 02:10 PM
Adjusting Pitch Bend Range on PC rwjaglee Digidesign Hardware & Software 0 03-08-2002 12:18 AM
