Go Back   Avid Pro Audio Community > Legacy Products > Aspera DigiDelivery
Old 02-03-2009, 11:35 AM
cmarkle_aspera cmarkle_aspera is offline
Default Please update any firewall rules permitting access to the DD central site
Folks,
Chris Markle here from Aspera with a post central site transition message... If you have any firewall policies that permit access to the DigiDelivery central site, they will probably need to be updated since the central site IP address has changed. The old central site was secure.digidesign.com at 209.10.227.229 and the new one is dgd.asperasoft.net at 75.101.141.64. Some of you (probably the larger companies) may have firewall or web proxy rules that need to be updated. You should permit http (port 80) and https (port 443) access from your site to the new central site at 75.101.141.64.
If you don't, you may see network test failures and/or users that post deliveries will hang at the end of the post operation and delivery emails will probably not get sent.
Thanks!
Chris
Old 02-04-2009, 03:16 AM
Default Re: Please update any firewall rules permitting access to the DD central site
Is this something I have to do as an admin on the server side only or does EVERY client have to do this as well?
thanks,
Frank.
P.S.: Is there a way to send an e-mail to all registered users on my server or do I have to click 70 times on every single address and paste the text 70 times into every email?
Old 02-04-2009, 07:32 AM
Frank,
Both the server and the clients will access the central site during their operation. The server always accesses the central site using https (tcp port 443). I believe the client uses both http (tcp port 80) and https (443).
As for getting all the email addresses in one shot, there is no way currently int he product to do that.
Chris
Port or Program rules for Outbound/Inbound connections for passing Windows 8 Firewall lehmann Artist Series 1 03-05-2014 04:17 PM
Will Aspera stop DD central site after Dec.2011? Vlad525 Aspera DigiDelivery 16 12-12-2010 11:22 PM
Transition of DigiDelivery central site services scheduled for January 24-25, 2009 Avid Technical Alerts 0 01-24-2009 02:37 PM
DigiDelivery central site transition scheduled for Friday, 1/23 6 PM PT (GMT - 8 hrs) cmarkle_aspera Aspera DigiDelivery 1 01-21-2009 02:02 AM
Transition of DigiDelivery central site services scheduled for January 24-25, 2009 cmarkle_aspera Aspera DigiDelivery 0 01-15-2009 11:57 PM
