Old 02-02-2009, 08:50 PM
Abdul Aziz Abdul Aziz is offline
Default Problem with recording vocals in Pro Tools 8
Hello to all,
While recording vocals they were going to track slightly behind the music tracks, and were off with the music and beat-and then I started getting these error messages telling me to remove some plug-ins and/or increase the buffer size. Can someone tell me how to resolve this issue so that my vocals will go to track in time with the music tracks, and tell me what I need to do to stop getting the cpu/error messages as to buffer size and removing plug-ins. Thanks!
I'm running my Pro Tools LE Mbox2 w/Triton Extreme Workstation, all into my Mac Book Pro 2.4 GHz Duo 2 Core, w/4GB's of SDRAM.
Old 02-02-2009, 09:02 PM
lcressy lcressy is offline
Default Re: Problem with recording vocals in Pro Tools 8
When you use plugins, it adds latency because there is more information your cpu has to process, and that time is the time difference you are experiencing. I would suggest that when you track, you don't use any plugins, save those for when you mix - you really want to hear what is actually being recorded, not what the plugin is making you think you are recording. If you record dry, you can get your buffer down to 128k, and you should be fine.
Old 02-02-2009, 09:41 PM
Sven62 Sven62 is offline
Hardware buffer setting is in SETUP > PLAYBACK ENGINE
Turn it down to 128 or so while you are recording (with no plugins or plugins disabled) and turn it back up to 512 or 1024 when you are mixing.
Old 02-02-2009, 10:05 PM
Paul David Paul David is offline
Agreed, unfortunately the "Talent" doesn't see it that way all the time. And I can understand their gripe. As a guitarist I wouldn't want to record completely dry, it kills the vibe of what you're doing.
If you can use a latency of 64 and just 1 reverb or delay or something to get them in the right mood. Or use a Jedi mind trick and get them to record dry and then use your chops to show them how amazing it sounds when you run it through your FX as soon as they're done. They may choose to take one for the team and record dry.
Static Problem when recording vocals Filmmaker123 Pro Tools Software (Mac) 0 10-20-2012 07:33 AM
Having a problem in Pro Tools when recording vocals musiclovin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 01-09-2010 09:20 PM
Problem With Recording Vocals in Pro Tools Visceral 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 06-09-2009 04:44 AM
Problem with recording vocals in Pro Tools 8 Abdul Aziz General Discussion 2 02-27-2009 05:00 AM
Problem recording vocals!!!Help!!!Delay!! dmt2828 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-11-2007 12:14 PM
