Avid Pro Audio CommunityHow to Join & Post • Community Terms of Use • Help Us Help YouKnowledge Base Search • Community Search • Additional Resources |
Dang it...I started a song at 16-bits never figuring it would be used for anything but a rough demo, but now the client wants to use what we've done in 16-bits for the master.
Any way to change the session to 24-bits? Will I have to do a new session and then import session data from the current one?
Larry PTLE8/002r;OS 10.6.4 2 x 2.26Ghz quadcore,6GB RAM, Waves Platinum, many other plugins... |
Consolidate all the audio tracks and import into a new 24 bit session. There's no way to convert the present session AFAIK.
Asus x99, Intel i7 6800K, 32 gig DDR4, GeForce 750 Ti, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs and Midas.............................. https://www.facebook.com/search/top/...0sound%20works www.capricornsoundworks.com The better I drink...the more I mix..... ![]() BTW, my name is Dave, but most people call me.........................Dave |
When you use the "File>Save Copy In" command, it creates a copy of your session and allows to define new session parameters such as Pro Tools version/ Audio File Type/Bit Depth/Sample Rate etc..
If you only make the one change to "Bit Depth" you'll be creating a copy of your session, but in 24 bit. *Just make sure to check the box for "All Audio Files" under "Items to Copy".
If you don't have it backed up, do you really have it? [ Mac Pro 4x2.66 | 3x23" | 5GB | 4x500GB int. - 4x500GB ext. | 10.5.5 | PT8 003R | Command|8 | BM-5A's ] [ Macbook Pro 2.16 | 17" | 2GB | 1x120GB int. - 2x250GB ext. | 10.5.5/XPproSP2 | PT8 Mbox2Micro ] |
Thanks. I'll give that a try.
Why, What's the benefit if the recording has already been done?
I tried the Save Copy In... and it worked! If you select 24-bits for your new session (coming from a 16-bit session), it automatically forces you to copy all files anyways - which makes sense. Thanks Night Train!
(I wasn't clear in how much of the recording had been done already) The benefits I can think of are at least these: 1. Although I have the guitar, drum tracks (from Drumcore) and an imported bass track at 16-bits, I don't have the final lead or background vocals, so the new vocals would benefit. 2. There will also probably be an overdubbed acoustic guitar and who knows what else (handclaps or some other live percussion). 3. The Native Instruments B4II sounds should benefit from the 24-bit resolution. VI's in general should sound better. 4. My Reverb and Delay plugins should sound better as well. 5. I THINK the plugins (EQ & Compression) on the 16-bit tracks will sound better because they now have 8 more bits with which to calculate changes and output those changes (more precision). 6. Certainly plugins on the master fader will benefit when summing tracks. Overall, the track does sound "bigger" in the new session, but that may simply be wishful hearing.... ![]()
![]() Quote:
When a file changes from 16 bit to 24 bit, does it "up-convert" (meaning some more serious math) or does it "un-truncate" (meaning just tacking on the extra bits)?
The reason I ask is that I have read the when you go from 24 to 16 (truncating) that unless you use dither, the last 8 bits are simply hacked off.. I'm not sure that this is the whole story here... I would think that simply adding the extra bits might have implications for the dynamic range of the new, 24 bit files... ie they might only get so quiet before you have a constant noise floor or a cliff (if you follow me..)
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
What lwilliam said is partly right. Any changes to the (formerly) 16-bit audio itself will benefit from the extra resolution. However, the mixing should not benefit, assuming nothing else changes. As I understand it, real-time mixing in PT is supposed to be the same bit depth regardless of the session bit depth - it's like 40 bit floating point, or something fairly high like that. That's on any kind of track, including the master. However:
1. Any new Audio Suite processing will preserve 24 of the process's output bits rather than only 16. Remember, that means preserving 256 times as much resolution! Well worth it. 2. Any fades/crossfades will be made at 24 bit, which will make them sound much smoother. 3. Any new audio recorded will be captured with much greater detail. 4. Any stems (submixes committed to audio) done during mixing will benefit greatly. Any audio files left unchanged will simply have zeros stored in their eight least significant bits, and should sound exactly the same as they did in the 16-bit session. If you want your EQ plugs (except those that oversample) to sound better, convert to a higher sample rate. Sample rate is a time-domain attribute, while bit rate is an amplitude domain attribute. That is, a higher sample rate improves frequency resolution, while a greater bit depth improves dynamic resolution. If I understand right, PT's mix engine always uses the same high bit depth, but the sample rate varies with the session. Some plug-ins do their own oversampling, but they still have to convert back down to the current session sample rate to pass the audio on to the next plug-in or to the mix path.
David J. Finnamore Nyquist was right. PT 12.8.1 HD | Omni | macOS Sierra PT 12.8.2 | Saffire Pro 40 | Win7x64 |
flommer - you're thinking in the right direction. You're right that converting from 24 to 16 bit w/o dither simply hacks off the last 8 bits. Similarly, when converting from 16 to 24, 8 new bits get simply "hacked on."
Way to Convert Session Bit/Sample Rate??? From Within Session??? | Table Syrup Records | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-25-2011 09:48 AM |
convert session | SupreGlu | Pro Tools TDM Systems (Mac) | 5 | 11-04-2010 06:52 PM |
Best way to convert LE session to HD session? | ctyelvis | Pro Tools TDM Systems (Mac) | 8 | 09-19-2010 09:44 PM |
How Can I Convert a Session From 7.0 to 6.9.1 ? | Leeb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-14-2007 07:31 PM |
Convert Mac (LE 5.x) session to PC (LE 6.9) ... | bigbottombass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-06-2005 12:06 AM |
