Digi-003 Rack LE 7.4 firmware update problem
Greetings! Upon launching ProTools is recieve the prompt to upgrade my firmware from V7.4.0.320 to V7.4.0.309. When I do so, the progress bar completes in 10 to 20 minutes, ProTools closes, and I'm back to my desktop. The cycle repeats every time I open ProTools. Any suggestions? Thanks,
Mike. SiSoftware Sandra System Processor Model : Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz Speed : 3.01GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Internal Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing System System : System manufacturer P5K Deluxe Mainboard : ASUSTeK Computer INC. P5K Deluxe Bus(es) : ISA PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes System BIOS : American Megatrends Inc. 0902 Total Memory : 2GB DIMM DDR2 Chipset Model : ASUS P35/G33/G31 Processor to I/O Controller Front Side Bus Speed : 4x 334MHz (1.34GHz) Total Memory : 2GB DIMM DDR2 Memory Bus Speed : 2x 534MHz (1.07GHz) Video System Adapter : ATI Radeon HD 3400 Series (512MB, PCIe 2.00 x16, PS3.0, VS3.0) Graphics Processor Adapter : ATI Radeon HD 24XX (RV610) (1.02, 512MB) Storage Devices WDC WD1600AAJB-0 160GB (ATA100, 3.5", 7200rpm, 8MB Cache) : 149GB (C:) (E:) WDC WD1600AAJB-0 160GB (ATA100, 3.5", 7200rpm, 8MB Cache) : 149GB (D:) Logical Storage Devices Hard Disk (C:) : 29GB (NTFS) @ WDC WD1600AAJB-0 160GB (ATA100, 3.5", 7200rpm, 8MB Cache) PT Files (E:) : 88GB (NTFS) @ WDC WD1600AAJB-0 160GB (ATA100, 3.5", 7200rpm, 8MB Cache) Back Up (D:) : 149GB (NTFS) @ WDC WD1600AAJB-0 160GB (ATA100, 3.5", 7200rpm, 8MB Cache) 3.5" 1.44MB (A:) : N/A Peripherals LPC Hub Controller 1 : ASUS (ICH9) LPC Interface Controller Audio Device : ASUS (ICH9) HD Audio Controller Audio Codec : Analog Devices AD1988B Sound Chip Audio Device : PC Partner RV620 Audio device [Radeon HD 34xx Series] Serial Port(s) : 1 Disk Controller : ASUS JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : ASUS (ICH9) USB Universal Host Controller USB Controller 2 : ASUS (ICH9) USB Universal Host Controller USB Controller 3 : ASUS (ICH9) USB Universal Host Controller USB Controller 4 : ASUS (ICH9) USB2 Enhanced Host Controller USB Controller 5 : ASUS (ICH9) USB Universal Host Controller USB Controller 6 : ASUS (ICH9) USB Universal Host Controller USB Controller 7 : ASUS (ICH9) USB Universal Host Controller USB Controller 8 : ASUS (ICH9) USB2 Enhanced Host Controller System SMBus Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Send To Microsoft OneNote Driver (300x300, Colour) Network Services Network Adapter : Linksys Wireless-N PCI Adapter WMP300N - Packet Scheduler Miniport (Ethernet, 39Mbps) Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 Performance Tips Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected |
Re: Digi-003 Rack LE 7.4 firmware update problem
Your report doesn't seem to show which firewire card or controller you have. Are you sure you posted the entire report?
I'd say that's the most suspect - incompatible firewire controllers/cards are usually the problem. |
I was trying to use the ASUS P5K Deluxe w/P35 chipset on-board firewire, but have since ordered the SIIG NN-440012-S8 firewire card. We'll see how that works out. Thanks.
I’m still unable to update my 003 Rack firmware. My PT is essentially useless with buffer underflow errors at ANY h/w buffer size. The progress bar gets to 100% and the computer returns to the desktop. I’m using the Digi-approved SIIG Firewire card on the Digi-approved ASUS P5K board w/P35 chipset. I’ve disabled “Load Sytem Services” and “Load Startup Items” in msconfig. My PT audio is on an secondary 7200 rpm 9ms seek time Western Digital HD, 2GB ram, DAE Prefs is deleted, Digidesign Databases folder is deleted, Volumes is deleted (per PT General Troubleshooting tips), Drive Indexing is disabled, DMA is enabled. I've already returned the 003 Rack for Sytem Clock and sample rate errors. Any ideas?
Thanks! SiSoftware Sandra – System Processor Model : Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz Speed : 3.01GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Internal Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing System System : System manufacturer P5K Deluxe Mainboard : ASUSTeK Computer INC. P5K Deluxe Bus(es) : ISA PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes System BIOS : American Megatrends Inc. 0902 Total Memory : 2GB DIMM DDR2 Chipset Model : ASUS P35/G33/G31 Processor to I/O Controller Front Side Bus Speed : 4x 334MHz (1.34GHz) Total Memory : 2GB DIMM DDR2 Memory Bus Speed : 2x 534MHz (1.07GHz) Video System Adapter : ATI Radeon HD 3400 Series (512MB, PCIe 2.00 x16, PS3.0, VS3.0) Graphics Processor Adapter : ATI Radeon HD 24XX (RV610) (1.02, 512MB) Storage Devices WDC WD1600AAJB-0 160GB (ATA100, 3.5", 7200rpm, 8MB Cache) : 149GB (C:) (E:) WDC WD1600AAJB-0 160GB (ATA100, 3.5", 7200rpm, 8MB Cache) : 149GB (D:) Logical Storage Devices Hard Disk (C:) : 29GB (NTFS) @ WDC WD1600AAJB-0 160GB (ATA100, 3.5", 7200rpm, 8MB Cache) PT Files (E:) : 88GB (NTFS) @ WDC WD1600AAJB-0 160GB (ATA100, 3.5", 7200rpm, 8MB Cache) Back Up (D:) : 149GB (NTFS) @ WDC WD1600AAJB-0 160GB (ATA100, 3.5", 7200rpm, 8MB Cache) 3.5" 1.44MB (A:) : N/A Peripherals LPC Hub Controller 1 : ASUS (ICH9) LPC Interface Controller Audio Device : ASUS (ICH9) HD Audio Controller Audio Codec : Analog Devices AD1988B Sound Chip Audio Device : PC Partner RV620 Audio device [Radeon HD 34xx Series] Audio Codec : AMD (ATI) AA01h FireWire/1394 Controller 1 : Avlab Technology TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller System SMBus Controller 1 : Intel 801xx/63xx SMBus Network Services Network Adapter : Linksys Wireless-N PCI Adapter WMP300N - Packet Scheduler Miniport (Ethernet, 1Mbps) Operating System(s) Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 |
Thanks DigiTech for dumping the sales pitch posts
Have you disabled your network card and any other extraneous hardware? What are the other error numbers you're getting in Pro Tools (they may clue is in as to where the problem is originating)?
Which version of Pro Tools do you have installed? Were there any recent changes to your computer? Was Pro Tools working properly at some point? |
What's the exact error message that you get?
albee1952, please read the post, I'm not selling anything. I have disabled my wireless and audio in Device Manager. When I let PT run I get error 6085 within 20 seconds. (My hope is that when I'm able to complete the firmware upgrade, that error may be solved.) I'm running LE 7.4. The computer is new, built from parts listed in the following Sandra report. While I ran Digi 001 successfully for many years, this upgrade to the 003 Rack hasn't yet been operable. I am using the same hard drives that I was using with the 001, which store files created originally on the 001. I've tried two different pci slots for the firewire card, and two Digi-supplied firewire cables. Perhaps reinstalling the PT software? Does anyone see any other possible hardware incompatabilities that I may have missed?
Thanks, Mike. SiSoftware Sandra – System Processor Model : Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz Speed : 3.01GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Internal Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing System System : System manufacturer P5K Deluxe Mainboard : ASUSTeK Computer INC. P5K Deluxe Bus(es) : ISA PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes System BIOS : American Megatrends Inc. 0902 Total Memory : 2GB DIMM DDR2 Chipset Model : ASUS P35/G33/G31 Processor to I/O Controller Front Side Bus Speed : 4x 334MHz (1.34GHz) Total Memory : 2GB DIMM DDR2 Memory Bus Speed : 2x 534MHz (1.07GHz) Video System Adapter : ATI Radeon HD 3400 Series (512MB, PCIe 2.00 x16, PS3.0, VS3.0) Graphics Processor Adapter : ATI Radeon HD 24XX (RV610) (1.02, 512MB) Storage Devices WDC WD1600AAJB-0 160GB (ATA100, 3.5", 7200rpm, 8MB Cache) : 149GB (C:) (E:) WDC WD1600AAJB-0 160GB (ATA100, 3.5", 7200rpm, 8MB Cache) : 149GB (D:) Logical Storage Devices Hard Disk (C:) : 29GB (NTFS) @ WDC WD1600AAJB-0 160GB (ATA100, 3.5", 7200rpm, 8MB Cache) PT Files (E:) : 88GB (NTFS) @ WDC WD1600AAJB-0 160GB (ATA100, 3.5", 7200rpm, 8MB Cache) Back Up (D:) : 149GB (NTFS) @ WDC WD1600AAJB-0 160GB (ATA100, 3.5", 7200rpm, 8MB Cache) 3.5" 1.44MB (A:) : N/A Peripherals LPC Hub Controller 1 : ASUS (ICH9) LPC Interface Controller Audio Device : ASUS (ICH9) HD Audio Controller Audio Codec : Analog Devices AD1988B Sound Chip Audio Device : PC Partner RV620 Audio device [Radeon HD 34xx Series] Audio Codec : AMD (ATI) AA01h FireWire/1394 Controller 1 : Avlab Technology TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller System SMBus Controller 1 : Intel 801xx/63xx SMBus Network Services Network Adapter : Linksys Wireless-N PCI Adapter WMP300N - Packet Scheduler Miniport (Ethernet, 1Mbps) Operating System(s) Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 |
Yea, firmware updated! Here's how:
1. Returned 003 Rack for a replacement- cleared up the Audio Clock and Sample Rate error. 2. Returned Gigabyte w/p45 chipset motherboard for an ASUS P5K Deluxe w/P35 chipset. 3. Installed SIIG Digi-approved Firewire card. 4. Disabled “Load Sytem Services” and “Load Startup Items” in msconfig, and every device possible. 5. Enabled DMA, disabled hard drive Indexing. 6. Loaded the latest PACE drivers. 7. Deleted Digidesign Databases folder, DAE Prefs folder, Volume folder. 8. Removed my PCI Linksys wireless card so the firewire card is the only PCI device. I now get error -6085 after one or two minutes of playback, and my comuter is useless except for ProTools, but these are subjects for another time. Thanks for all the suggestions and insights! |
Same problem regarding the firmware upgrade, Pro Tools would shut down right before or just as the progress bar was completed.
Tried the msconfig modification prior to upgrading and it worked very well. Thanks. |
Digi 003 Rack Firmware Update Clarification | DGraham | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-13-2009 07:04 AM |
Firmware Update HELP. My 003 Rack will not update Firmware. | New003RackUser | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-17-2007 09:01 AM |
Firmware update/problem for 002 Rack | cconley | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-06-2004 08:05 PM |
I Can't update digi 002 rack firmware please help! | Escape | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-18-2004 09:11 AM |
002 rack firmware update killed my rack and OS X | bandgear | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 11-01-2003 08:25 PM |
