Old 10-22-2008, 06:15 AM
Abbot Abbot is offline
Default C24 with Logic Pro
Hi !
Can I use Digidesign 192I/O, SYNC i/o, C24 and Logic. It seems to me that C24 will not work with Logic. Is it right??
Old 10-22-2008, 07:06 AM
TCDet TCDet is offline
Default Re: C24 with Logic Pro
C/24 is a Pro Tools Controller. Are you speaking of Logic as a front-end?
Or logic in-sync with PT's?
I have Logic studio so I give it a whirl (time permitting) but I anticipate not allot of alignment between applications.
Now in Logic you can map-for-Pro-Tools key commands which may add some behavior similarities and thus functionality with the C/24 (!?!)
However I prefer Logic key commands so I know Logic on all systems....
I personally use Logic in-sync and monitor via a MOTU 896 interface. This I monitor via the C/24's St1 or Aux-sur.
In logic when ready, I export all tracks as audio and import into PT's.
This generally works fine when I need what logic has in libraries n such.
I also use this for all other syncable applications. Sync via the IAC bus's Beat clock and MTC.
Old 10-22-2008, 08:01 AM
DigiTechSupt's Avatar
TCDet is correct - the C|24 isn't usable as a controller for Pro Tools.
You can, however, use the 192 and Sync in DAE/DTDM mode with Logic (assuming you have compatible versions of Logic and Pro Tools installed).
Avid Audio Tech Support
Support FAQ
Old 10-22-2008, 01:50 PM
Table Syrup Records's Avatar
Table Syrup Records Table Syrup Records is offline
Oooops. That sounds like a big glitch! LOL
Maybe it'll get fixed in the firmware!?
HAHAHAHAHAAAAAAAAAAA
I'm sorry.... so funny to me.
"C|24 isn't usable as a controller in Pro Tools"
hahahhahahaaaaaaaaa
I am so sorry, I can't help it. I do the same thing all the time, but this one was great!!!
MAKE IT A STICKY!!!!!
You gotta see the humor in that!
Shorty: Table Syrup Records
Mac Pro 5,1 3.33 GHz Hex, 32GB
EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23"
OSX Sierra
Pro Tools HD 11.2.2
Waves IOS, IOX, STG2412
Extreme Server (x2)
Logic Pro X, DSP Quattro, Final Cut Pro X
Waves Mercury+SSL+AbbeyRoads
Trident S65 with embedded US-2400
Live:
2012 Mac Mini, Dual SSD, i7 2.4, 16GB
Win 10, OSX Sierra
LV1, MRSG
Hardware from above (same gear)
Dual Dell P2418HT Touch Screens
Waves Icon X (x2), M, with Screens
Custom enclosure
Logic 8 to logic 7 session won't open! saving procedure need crizdee Pro Tools TDM Systems (Mac) 9 04-26-2008 08:09 PM
Logic Pro users: Midi & audio between Logic & PT dtmprod Pro Tools TDM Systems (Mac) 4 09-24-2006 04:16 PM
tdm logic plug in automation in logic 7? quincygriffin Pro Tools TDM Systems (Mac) 5 05-23-2005 09:08 AM
Logic 5.0.0 crashes all the time.. Is there a Logic expert around here? uno1234 Pro Tools TDM Systems (Mac) 13 04-28-2002 04:23 PM
Hello Logic users.......Please explain about Logic Midi elik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-04-2001 01:35 AM
