Old 07-09-2008, 02:37 AM
dee dee dee dee is offline
Default Plugin \"Set Root Settings Folder\" PROBLEM
Hi folks,
Im new around here, so howdy all!
I have a problem with my plugins. I'm running: OS 10.4.11, PT LE7.4, DIGI003 Rack, and probably the culprit: novation Remote 49SL Compact.
Now I reckon it was just after installing the Novation Software that this happened, so it could well be that... BUT
I have set all the p[lugins to the correct root settings folders in order to access the presets via the + and - buttons... now they don't work... that is, the buttons aren't "highlighted"...
describing these things is sometimes a little tricky, so I hope i've described the problem sufficiently, and if not i'll do my best to expand...
my thanks in advance
dd
Old 07-09-2008, 09:46 PM
Default Re: Plugin \"Set Root Settings Folder\" PROBLEM
Howdy all...
I think, so far, I have solved the prob...
I trashed all the prefs for PT and Remote SL. After trawling through a bunch of forums and the DIGI and Novation answerbases (to no avail, specifically anyway), I decided to go the pref trashing method...
So, if anyone has the same prob, try that. Seems to have worked for me.
Cheers
Why can't I set my plugins root settings folder outside PT's default folder? RiF Pro Tools 9 4 09-26-2011 12:11 PM
Unable to save session copies w/ Root Settings Folder nuancerec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-03-2011 03:05 PM
Plug-In Settings root folder problem TJS Pro Tools TDM Systems (Win) 1 06-12-2008 04:03 AM
Cannot save plug-in settings to Root Settings folder SimonORorke Pro Tools M-Powered (Win) 1 01-18-2008 09:38 PM
Plugin root folder???? nukmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-13-2004 12:32 PM
