Avid Pro Audio Community |
I'm getting this after I installed the AIR box set.
The error pop up occours at the Setting Up Peripherals/Initalizing Controllers and before Initialising Machine Control. Ive uninstalled 7.4, Reinstalled 7.4 Done a clean unistall of 7.4 Uninstalled 7.4cs5, Reinstalled 7.4cs5 Did reinstalls of the MPTK, DV Toolkit2 and all of the Air plugs. I Ran all of the Dev Partners, BombFactory, and Digidesign Plug in Updaters. Moved the plugs to the unused plug ins folder- Moved them back. I Uninstalled-Reinstalled all my Midi Drivers and rebooted along with downloading and installing the latest Pace Drivers. Any body seen this particular message? Searching the DUC turned up nothing. Pro Tools itself seems to run fine once the error is clicked through and PT loads. I could restore from a back up but I want answers What is CFnd.dll? What program does it belong to if not PT? and what is PT dependency on it.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Nudge
Well as it turns out CFnd.dll is not missing-its alive and well in the same location on both drives of my dual boot system.
C:\Program Files\Digidesign\Pro Tools D:\Program Files\Digidesign\Pro Tools The problem would appear to be that PT cannot find it even though its where its supposed to be. Time to try a clean unistall again or the Nuke PT utility.
I am having the same problem, although I have just ignored it with no bad consequences.
I cam here to find a solution - am surprised to find so little on it. I am using Vista, so maybe it's a Vista thing. Michael |
Hi sunburst,
If I open the event viewer in XP, there is often an error saying: "Faulting application protoolsle.exe version 7.4.0.324, faulting module cfnd.dll, version 7.4.0.324, fault address 0x0003491f." I don't know which consequences there are in PT, I only know that I frequently have this start/play bug in PT. Don't know if it has got anything to do with it.
002R BLA mod, PT LE 8.0.1, MP Toolkit 2, Intel Quad, 4GB Ram, System 500GB, Audio 500, Samples 500 SATA, Backup 1TB, Win XP SP3 HD Native, HD IO 16x8x8, PT 10, Win 7 Pro 64, Asus P8Z68-V Pro Gen3, 2600K at 4.6 GHz, 16 GB Ram, audio PC bundle from scan.co.uk |
I uninstalled and re-installed some AMD things to do with graphics. After this I had the messsage above : (A required DLL file, CFnd.dll was not found) and have been unable to even open ProTools ..
Does anyone know how I can get hold of the file to try replacing it and hopefully finally opening ProTools and getting on with recording my music ! I need a specific file from a specific site .. preferably give me the URL .. So here's hoping I can find file CFnd.dll as a free download and get it back on my comp in the appropriate place ! Thanx in advance .. Gregory |
What's sad is I remember getting rid of this message and solving the problem. But 5 years later I can't remember how....
I dont remember this relating to AMD graphics but since thats what I normally use thats certainly possible. I have a hunch the issue was duplicate files and the solution was deleting one. This was within each partition. Please dont delete anything at random though since it might kill your system.
Interestingly enough a search of my desktop - which is still running XP turned up CFnd.dll in reference to list generated by the plug in version list. Back in 2008. Yeah I'm a digital pack rat.
I have no idea if this will help but im going to copy and paste it here. At least you know where to look for it. You might search your system and see if it exists. I:\Program Files\Digidesign\Pro Tools\ .. Not Available AAFCOAPI.dll 8.0.0.314 asifont.map Not Available Asiport.rsr Not Available BUI.dll 8.0.0.314 BUI_Resource404.dll 8.0.0.314 BUI_Resource411.dll 8.0.0.314 BUI_Resource412.dll 8.0.0.314 BUI_Resource804.dll 8.0.0.314 Cfd.dll 8.0.0.314 Cfd_Resource404.dll 8.0.0.314 Cfd_Resource411.dll 8.0.0.314 Cfd_Resource412.dll 8.0.0.314 Cfd_Resource804.dll 8.0.0.314 CFnd.dll 8.0.0.314 CFnd_Resource404.dll 8.0.0.314 CFnd_Resource411.dll 8.0.0.314 CFnd_Resource412.dll 8.0.0.314 CFnd_Resource804.dll 8.0.0.314 CompleteToolkit.dll 7.4.0.0 DAE.dll 8.0.0.314 DAE.dll.rsr Not Available DAE_Resource404.dll 8.0.0.314 DAE_Resource411.dll 8.0.0.314 DAE_Resource412.dll 8.0.0.314 DAE_Resource804.dll 8.0.0.314 Databases Not Available DFW.dll 8.0.0.314 DFW.idb Not Available DFW.vdb Not Available DFW_KeyHook.dll 8.0.0.314 DFW_Resource404.dll 8.0.0.314 DFW_Resource411.dll 8.0.0.314 DFW_Resource412.dll 8.0.0.314 DFW_Resource804.dll 8.0.0.314 DHS.dll 8.0.0.314 DHS.idb Not Available DHS.vdb Not Available DHS_Resource404.dll 8.0.0.314 DHS_Resource411.dll 8.0.0.314 DHS_Resource412.dll 8.0.0.314 DHS_Resource804.dll 8.0.0.314 DigidesignRegistration.exe 0.1.0.7 DigiExt.dll 8.0.0.314 DigiMIDI.dll 8.0.0.314 DigiMIDIServices.dll 8.0.0.314 DigiMIDI_Resource404.dll 8.0.0.314 DigiMIDI_Resource411.dll 8.0.0.314 DigiMIDI_Resource412.dll 8.0.0.314 DigiMIDI_Resource804.dll 8.0.0.314 DigiPlatformSupport.dll 8.0.0.314 DigiRefClock.dll 8.0.0.314 DigiReg.file Not Available digiSPTIService.exe 8.0.0.314 DigiSyncReader.dll 8.0.0.314 DigiVout.qtr Not Available DigiVout.qtx Not Available DirectIO.dll 8.0.0.314 DMC.dll 8.0.0.314 DSI.dll 8.0.0.314 DSPManager.dll 8.0.0.314 DUI.dll 8.0.0.314 DUI.idb Not Available DUI.vdb Not Available DUI_Resource404.dll 8.0.0.314 DUI_Resource411.dll 8.0.0.314 DUI_Resource412.dll 8.0.0.314 DUI_Resource804.dll 8.0.0.314 ExpansionHD_Firmware.bin Not Available FFmt.dll 8.0.0.314 FFmt_Resource404.dll 8.0.0.314 FFmt_Resource411.dll 8.0.0.314 FFmt_Resource412.dll 8.0.0.314 FFmt_Resource804.dll 8.0.0.314 GDIPlusWrapper.dll Not Available Grooves Not Available LGC.dll Not Available NeoAccess.dll 8.0.0.314 NTL.dll Not Available OMFToolkit.dll 8.0.0.314 Plug-Ins.lnk Not Available Pro Tools Utilities Not Available ProTools.dll 8.0.0.314 ProTools.idb Not Available PROTOOLS.RSR Not Available ProTools.vdb Not Available ProToolsApp.idb Not Available ProToolsApp.vdb Not Available ProToolsLE.cat Not Available ProToolsLE.exe 8.0.0.314 ProTools_Resource404.dll 8.0.0.314 ProTools_Resource411.dll 8.0.0.314 ProTools_Resource412.dll 8.0.0.314 ProTools_Resource804.dll 8.0.0.314 RTEngineDiag.dll 8.0.0.314 Session Templates Not Available Sib.dll Not Available Sib_Resource404.dll Not Available Sib_Resource411.dll Not Available Sib_Resource412.dll Not Available Sib_Resource804.dll Not Available SoftwareUpdater.exe 8.0.0.314 SoftwareUpdater_Resource404.dll 8.0.0.314 SoftwareUpdater_Resource411.dll 8.0.0.314 SoftwareUpdater_Resource412.dll 8.0.0.314 SoftwareUpdater_Resource804.dll 8.0.0.314 StreamManager.dll 8.0.0.314 SystemLink.dll 8.0.0.314 Trns.dll Not Available updater-version.properties Not Available xerces-c_2_6.dll 2.5.0.0 End Directory: I:\Program Files\Digidesign\Pro Tools I:\Program Files\Digidesign\DAE\ Find Function returned no results for directory: I:\Program Files\Digidesign\DAE\* END
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Please help wrong cfnd file in /Frameworks/CFnd.framework/Versions/A/CFnd | bobo94 | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac) | 1 | 07-05-2010 10:08 AM |
| A required .dll file was not found... | tonejunkee | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) | 2 | 02-15-2010 04:28 PM |
| invalid PTLE 6.4, required dll file,File.dll not found | martinleys | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) | 1 | 11-13-2007 08:41 PM |
| A required file, missing DAE.dll , Blue screens | Jenk2k | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) | 0 | 09-13-2006 08:27 PM |
| A Required DLL FIle | Princeton | General Discussion | 0 | 12-03-2000 02:31 PM |
