Avid @ NAMM 2018
Old 06-13-2008, 08:37 AM
Cary_Clark Cary_Clark is offline
Default Buzzing during audio playback
I am working on a G5 1.8GHz PPC Mac with Protools LE 7.3.1. My system preferances are configured to have my Mbox 2 manage all of my computer audio. I have noticed that when the computer is on and not running applications with sound content my speaker system is silent. When I launch or use any applications that play back audio (such as protools or itunes) my speakers begin to buzz while playing or standing by. When I exit the program the buzzing stops. Has anyone else had this problem and how can it be fixed?
Old 06-13-2008, 04:12 PM
Phil Ogden Phil Ogden is offline
Default Re: Buzzing during audio playback
Deleting Prefs and DDB's is always worth a shot with random problems like these. Failing that, it maybe some kind of RF interference. Do the cables to your monitors pass near anything that might cause interference (e.g VGA monitors).
Also, there's a bit on Answerbase about Mbox interference issues (reproduced below),
Mbox or Mbox 2 experiences whine or high pitched noise while in use.
The problem is related to either the computer itself, or to ground loops induced by plugging gear into multiple outlets or just plain bad grounding. The Mbox is generally not the culprit.
The following steps can help resolve the issue:
1) Plug all gear into the same outlet and/or make sure your outlets have a good ground.
2) Use TRS (balanced) cables from the outputs of the Mbox.
3) Get a Monster 'Ultimate Performance' USB Cable
If you are on a G5 and the above recommendations don't help, you can install the Apple Developer Tool called CHUD which helps remove noise cause by the processor to be eliminated.
More information on installing CHUD: http://www.digidesign.com/index.cfm?...1&itemid=20534
Further troubleshooting and help with 60 cycle hum issues
http://www.myspace.com/philogg
Old 12-20-2008, 12:42 PM
NickRParsons NickRParsons is offline
Did you ever find an answer for this?
My g5 is doing the same thing. I've bought amazing cables, and tried the xtools and chud installation. the CHUD installation won't do what it says it will do - there's no processor option in the system prefs, I tried uninstalling it and now I can't even reinstall - seriously annoying.
Any results or ideas from anyone else?
Running 10.5.6 and PT 7.4.2 LE. Thanks!
Low Buzzing During Recording and Playback carterisgod41 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-07-2011 03:40 PM
Buzzing during audio playback Cary_Clark Pro Tools TDM Systems (Mac) 0 06-13-2008 12:01 PM
Buzzing on Playback??? JRodJr Pro Tools M-Powered (Mac) 0 03-21-2006 08:19 PM
buzzing sounds, record & playback Gringo Viejo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-31-2005 10:33 AM
Buzzing During Playback JoeLo Pro Tools TDM Systems (Win) 2 07-28-2005 11:23 AM
