Old 06-12-2008, 10:44 AM
JonesH JonesH is offline
Default Compacting sessions
Hi!
I hope this hasn't been asked too many times before.
I want to compact my session; I've done all edits and such so now I want to select all my regions and compact them into sound files so that I can throw away all the leftover parts from the audio files.
This should be simple, I expected and selected all (active regions); trying the compact command on all selected regions with a padding setting of 1 s. This produced remarkably little results. The regions are still only part-regions of larger sound file regions wich I can't delete for obvious reasons.
What am I doing wrong? Thank you.
I just wanna do engineering...
(as opposed to make music :/ )
Old 06-12-2008, 11:13 AM
Slim Shady Slim Shady is offline
Default Re: Compacting sessions
You're using the wrong command. You want to consolidate the audio, not do the compacting thing. Once all tracks are consolidated, you can then remove/delete the old/unused smaller regions from the region bin.
Old 06-12-2008, 11:39 AM
Yes, that would have been the obvious solution, but I want to be able to adjust my fades afterwards, not print automation and fades to audio and so on. Surely there is a way to do this?
Or do I have to manually consolidate every region and then delete the other regions?
Compacting .wav files Reckless Erik Post - Surround - Video 0 02-10-2006 04:11 AM
Mess after compacting jofromabove 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-06-2005 05:27 PM
compacting error Ale Pro Tools TDM Systems (Mac) 4 09-13-2002 08:10 AM
Compacting Files rfreeman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-21-2002 10:49 AM
Compacting and cleaning up sessions? Skwaidu Tips & Tricks 16 08-05-2001 08:47 AM
