Old 04-22-2008, 02:40 PM
kieuphucuong kieuphucuong is offline
Default Problem when using Nuendo 3!
I use Mbox 2 pro to record vocal. When I record with Protool LE, it's ok. But when I record with Nuendo 3, I can't hear any sound from my microphone.
How can I do to hear vocal when I record with Nuendo 3?
Old 04-22-2008, 03:48 PM
JMS40 JMS40 is offline
Default Re: Problem when using Nuendo 3!
I assume you've assigned the Digi ASIO driver in the VST Connections section and your hardware isn't the problem.
Is "Direct Monitoring" checked off under Device settings?
Do you have the little brown Monitor button pressed on the channel strip in the mixer section? That has to be activated in order to moniter the input of each track you are going to record to.
Problem with Windows 7 64 bit / Nuendo 32 bit / EuControl 2.5.7 Klosse Artist Series 2 12-07-2011 02:50 PM
Nuendo: MC Mix: Show meters in Nuendo ha2dorff Artist Series 1 04-24-2011 04:13 PM
help with hd 7.4 - nuendo mtc sync problem peeweedrummer Pro Tools TDM Systems (Mac) 3 07-09-2009 11:34 AM
Driver problems with 002 rack + nuendo problem Acle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-21-2006 01:19 PM
Problem opening Nuendo 2 OMF in DigiTranslator jdaboll Pro Tools TDM Systems (Mac) 6 05-26-2004 08:33 PM
