Old 03-14-2008, 12:00 PM
Gothboy's Avatar
Gothboy Gothboy is offline
Default Can\'t open Reason Adapted 3.0 after install
I can't open Reason Adapted 3.0 on my Mac PPC after first install. The install process off the disk instructs me to just drag the folder onto the Hard drive but when I try and open RA I get a "Failed to setup Rex system properly, exiting." error window. :?: Never had this trouble with RA 2.5 which I do still have installed because I have 2 songs in the works That are using 2.5 and would like to keep it there. The install instructions say to keep the older version for songs that use 2.5....you just can't update those songs or open them in RA3. I just can't figure out why this won't open?! Any help from RA users most welcome.
Apple Mac Pro 2.88 GHz. Intel Xeon Quad core
16 GB RAM
Mountain Lion 10.8.5/El Capitan 10.11
Focusrite Saffire Pro 40
Ableton Live 9/Presonus Studio 3
I no longer use Pro Tools and just as happy!
Old 03-14-2008, 01:16 PM
Phil Ogden Phil Ogden is offline
Default Re: Can\'t open Reason Adapted 3.0 after install
Have you launched Reason in standalone mode? Apparently this is a one time excercise that's required to install certain rewire components.
http://www.myspace.com/philogg
Old 03-15-2008, 06:23 AM
Gothboy's Avatar
Yes, the first time I tried to fire it up after install was just in standalone mode....and I got the error. It's perplexing because it's the first time I had any problems like this with an install. I thought that it had something to do with RA 2.5 being already on there...but now I'm thinking it has nothing to do with it. I dragged 2.5 to the trash and re-installed 3.0 but still same error. I have a 30-day support with this Ignition pack, so I called tech. support yesterday....very nice guy on phone gave me some instructions on a possible remedy which came from propellerheads software(who give no support for RA 3.0, which is rather abysmal!):
"This alert sometimes pops up when launching Reason after another REX
compatible application has been installed."
Here's how to resolve this.
1. Perform a system wide search for REX Shared Library **
2. Delete all instances of found files with that exact name.
3. Launch Reason, and the file will be restored.
....but I don't think this applies...the only thing that came up with this search was a REX Shared Library alias, I deleted that but sill no go. I repaired disc permissions 3 times and then another re-install and still can't open the program. Really quite perplexing.
16 GB RAM
Old 03-15-2008, 01:38 PM
Gothboy's Avatar
.....now I'm getting a new error window....
"Remote system could not be installed because access to the global application support folder was denied"
"try running disc utilities then repair permissions and then reopening Reason"
I keep doing repair permissions but keep getting this error messege.
CAN....NOT....FIGURE...THIS....OUT.....
any help on this would be great.....the prop forum is just SO useless when it comes to RA.....just no support there or from prop themselves...which is shameful, really.
16 GB RAM
Old 03-18-2008, 06:40 AM
fonfon fonfon is offline
I have the same problem, please help me !!
"try running disc utilities then repair permissions and then reopening Reason" -> no ok...
THX
MacBook dualcore 2 2.4 / 2Go / 160hdd
Old 03-18-2008, 09:03 AM
DigiTechSupt's Avatar
Go to MacHD>Library>Application Support and trash:
Propellerhead Software (folder)
Reason Engine
ReWire
Rex Shared Library
Rex Shared Library Bundle
(if you don't see some of these, that's ok..)
Empty the trash, restart and relaunch Reason - it should reinstall all the proper components.
Avid Audio Tech Support
Support FAQ
Old 03-18-2008, 09:04 AM
Gothboy's Avatar
I can help you out on this one! Thanks to a very nice Digidesign support rep. I was able to figure out the problem. It seems that an existing version of Reason Adapted...in this case 2.5, can prevent the newly installed version from accessing the "Propellerheads Software" folder in the library>applications support folder. Once I deleted that and re-installed 3.0 the new version places a new "Propellerheads Software" folder in the applications support folder and the new version works. Which is good, but only after I let the installer put rewire 2 on there.
The only thing is that I still can't figure out how both can run on the same system as I'm led to beleive from the instructions on the disc...as only one can use that folder. I have 2 songs that are still currently using 2.5 so that's the only reason I care....I'll probably never use 2.5 again except for that. Let me know how this works for you!
16 GB RAM
Reason Adapted Update doesn't open with PT Talisker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 12-06-2010 03:31 AM
Reason Adapted Install Issue Average_Joe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-15-2006 06:22 AM
HELP! Cannot install Reason adapted on Macbook Pro joe doc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-16-2006 12:40 PM
Cannot install Reason Adapted (see last post) Gino Krishnadath 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-17-2006 09:12 AM
Reason Adapted won't open after PT 6.4 LE upgrade foges 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-25-2005 08:16 AM
