Avid @ NAMM 2018
Old 03-02-2008, 10:40 PM
joshua12 joshua12 is offline
Default Help!!! 003 rack not detected by i Mac!
This is my iMac spec -
Machine Name: Mac
Machine Model: iMac7,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.4 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache (per processor): 4 MB
Memory: 1 GB
mac os : 10.4.8
I already download os from 10.4.10 to 10.4.8, but iMac does not detect oo3. I have protools le 7.3(003 rack).
After I install protools and run the program, it shows messages that ' unable to locate digidesign hardware...'.
Firewire cable is ok, and the port on the back of imac is no problem. But When I connect 003 to my windows system computer, it works.
I do not understand why iMac can not detect 003.
iMac is totally new. Never installed any other program except protools.
I download prebind_script and once run it. It shows the message that there is no problem.
What shoud I do?
Old 03-02-2008, 10:53 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Re: Help!!! 003 rack not detected by i Mac!
If you really have "le 7.3" installed and not 7.3.1 for 003/003 Rack, it won't work. You need to make sure you have installed Pro Tools LE 7.3.1 from the installation disk included with the 003 Rack. From the Compatibility link above:
Compatibility
Pro Tools LE for Mac OS X Compatibility
http://www.digidesign.com/index.cfm?...4&itemid=23639
003 drivers required, included with Pro Tools LE 7.3.1 for 003 & 003 Rack
Administrator
Old 03-03-2008, 02:33 AM
I just installed protools le 7.3.1, but got same problem. 'unable to locate protools hardware...'
What i found is the green light beside firewire port on the back of 003 blinks. But When 003 was connected to windows computer, the green light was on. So it seems there is a connection problem. What should I check?
the firewireport seems ok, because yesterday I connected two macs with that port, and use the same firewirecable.
The green lamp blinks 9 times and off for a second, it repeats the pattern.
can u help? I'm exhausted.
Old 03-03-2008, 03:47 AM
denka's Avatar
denka denka is offline
Joshua, please edit your original post and delete your iMac serial number. Ebay thieves are very glad you supplied them with it.
AVID HD Native PCIe + HD OMNI; Digidesign 192 I/O (2x) & 96 I/O; Icon QCON Pro & QCON EX; Softube Console 1; NI Kontrol 25; Arturia SparkLE; UAD-2 Satellite DUO; UAD-2 PCIe DUO; Tascam DA-3000; TK Audio BC1-S; Warm Audio WA76; SSL XLogic Alpha Channel (x2); SSL X-PATCH; Lindell Audio 6X-500, 7X-500 & PEX-500 (all x2), lots of TCE & Lexicon reverbs; VintageMaker LittleOne 16/2 Summing Mixer; MUTEC MC3+ SmartClock; Mac Pro (2009) 8 Core 2.26; 24 Gb RAM; Pro Tools HD 12.8
Old 03-03-2008, 04:09 AM
thanks! I erased the serial number.
Old 03-03-2008, 06:27 AM
BradLyons BradLyons is offline
It sounds like you should contact the technical support staff at the dealer of which you bought the product, or Digidesign directly---so that you can be walked through the steps to see "what's missing".
Thank you, Brad Lyons
GC PRO- Pro Accounts Manager
(404)844-9758
blyons@gcpro.com
www.theaudioprofessional.com
Old 03-03-2008, 10:34 AM
DigiTechSupt's Avatar
Have you tried this with a different firewire cable? Some machines seem to have a problem with the longer cable that comes with the 003.
Avid Audio Tech Support
Support FAQ
Old 03-04-2008, 12:33 AM
Rob0214 Rob0214 is offline
Did you power the 003 on before the Mac?
Old 03-04-2008, 01:57 AM
your one guy your one guy is offline
why would digi sell a system with cables they know there having problems with???????
Old 03-04-2008, 09:54 AM
They were packaged before a few reports came in - there may still be stock out there with the longer cables, which may be the case here. It's very rare - we've only had a handful of confirmed reports and, given that we sell thousands of these units, the likelihood that someone may come across this is almost nil.
Support FAQ
003 rack not getting detected brainsout 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-11-2009 04:50 PM
no HW detected why? Joseph Vences 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-07-2009 08:26 PM
Digi 002 rack not detected paulinem 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-02-2008 11:55 PM
problem detected with audio clock Digi 002 rack Ben83 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-13-2006 10:35 PM
002 Rack not being detected, can't install drivers lonlonmilklover 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-18-2006 10:24 AM
