Old 01-24-2008, 10:52 PM
RichrdC RichrdC is offline
Default A Message But Not An Error Message
I'll say thanks in advance for any insights into something new that's just started happening. I'm running MP 7.3cs5 on a laptop, 3.06GHz with 2 gig of RAM, with an external 250 gig hard drive. I've been using the "Save Copy In" in order to save a different mix of a few sessions. Now, whenever I go to open a session, the original mix, I get this message...."The original disk allocation for this session cannot be used. Check the disk allocation window to see what's changed. Would you like so save a detailed report? No or Yes.." If I answer No, the message window closes and the session loads up. If I answer Yes, the window also closed and the session opened up. I don't know where the detailed report was saved or, what it is?? I don't know if I've messed something up, or this is the normal course of things. I've saved the copy in the same session folder as the original mix so when I open a session, I take one more step to open the link to the copy.. I'm hoping I'm concerned about nothing... Thanks again.
Old 01-26-2008, 04:38 PM
temetrepo temetrepo is offline
Default Re: A Message But Not An Error Message
i get this message if i work on LE with a 002 and then continue working on M Powered with a ProjectMix, i just hit no and continue working.
What i do notice is that the I/O in the projects match the ones on the 002 and not the PMIO
i go and reset them on the I/O window and everything goes back to normal.
Originally Posted by JustinA
"Soon" as in we should be refreshing our browsers, or "soon" as in ADC coming to LE?
Old 01-26-2008, 06:21 PM
yellowjacket yellowjacket is offline
You're just getting this message because the original files from the original copy of the session are now technically located in a different place. When doing a "Save Copy In", Pro Tools creates a new session folder, thus, the audio files are now in a different location in the computer. This message is just alerting you of that. Nothing to worry about really.
Cubase 5.5.1 :: Ableton Live 7.0.18 :: Pro Tools M-Powered 8.0.4
Windows XP Home SP3 :: Gigabyte GA-EP45-DS3R :: Core 2 Quad Q6600 2.4GHz :: 4GB DDR2-800
Mac OS X Leopard 10.6.4 :: Macbook Pro 2.16GHz :: 3GB DDR2-667
Access Virus TI Polar :: M-Audio Profire 2626 :: UAD-2 Duo :: UAD-1
Old 01-27-2008, 07:57 PM
Thanks guys for the thoughts. Yellowjacket, I thought through the issue and came to the same conclusion as you. Thanks again.
error message: saxylady77 Windows 1 02-15-2014 08:38 PM
DAE 35 error message williebarron3 macOS 1 02-20-2011 09:25 PM
Can't read full message in message boxes toftee001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-02-2006 10:35 PM
Help with error message crimson Pro Tools M-Powered (Win) 1 02-25-2006 09:08 PM
DAE error message 225 Tom Wheeler Digidesign Hardware & Software 2 08-15-2002 03:51 PM
