Old 12-19-2007, 09:57 AM
winampdevil winampdevil is offline
Default DAE error -13001 while starting PTLE7.4 - SOLVED
Hi there,
i've just installed PTLE 7.4/mbox2 within an admin-account, running w/o problems.
changing this account from admin to power-user and get a dae error -13001 during init the hardware.
installer said it's all right to run with a non-admin account.
running PT with another admin-account works fine.
config:
dell optiplex 755 (core2duo 2.66GHz, supported chipset, 2GB Ram, seperate ati-gfx-card)
mbox2, no other sound
winxp sp2 with the latest patches
quicktime 7.3
any ideas?
thanks
frank
Old 12-19-2007, 10:18 AM
livesoundguy livesoundguy is offline
Default Re: DAE error -13001 while starting PTLE7.4
What version of Windows are you running?
Also you should post complete computer specs as well (CPU, Chipset/MOBO, drives, etc.).
Old 12-19-2007, 10:25 AM
sorry... i've update my 1st post..
Old 12-20-2007, 06:21 AM
Default Re: DAE error -13001 while starting PTLE7.4 - SOLVED
My non-admin-user was NOT in the usergroup "pro tools users"
i 've changed this and anything was allright.
(but ther's no word in the manual.....)
frank
Old 01-03-2008, 03:34 PM
Troutman Troutman is offline
Did you had to reinstal Pro-Tools after changing that or did it started to work right away?
I'm having a similar problem, except I don't get an error message, it just hangs at startup. I've included my user in "pro-tools users", but it made no difference so far...
Old 01-03-2008, 03:49 PM
sinukus sinukus is offline
winampdevil's problem would have been that the user account he was trying to launch with didn't have the correct policy enabled. I don't know if the PT installer creates the Protools user, but the intended end user needs to be able to Increase Scheduling Priority or the 13001 error gets triggered. Of course there are certain security implications with this.
Below Zero Beats on 92.7 FM San Francisco
Sundays 8pm - Midnight
http://belowzerobeats.com
Old 01-03-2008, 06:07 PM
I understood that, it's just that I've spent almost a week digging info in the internet, trying to solve my problem (PT hangs when loading ) and I've tried so many things, I've run out of possible solutions to problems exactly like mine and started looking for similar problems and trying their solutions.
Basically I'm trying to recreate exactly what winampdevil did, because just adding my user to the PT user group didn't work...
Old 01-03-2008, 06:12 PM
OK - your not on vista. I'll answer on your original thread.
Old 07-28-2010, 01:25 PM
literatemoose literatemoose is offline
I just got this error with Windows 7 Professional 32 bit and Pro Tools LE 8.0.4 while using an administrator account. Help?
Old 07-28-2010, 01:30 PM
spkguitar's Avatar
Are you running Pro Tools as Administrator? (right click, select "Run as Administrator")
DAE Error 13001 TL4500 Pro Tools 10 6 10-27-2013 02:51 AM
Dae error -13001 Rockman413 Pro Tools 10 6 07-25-2013 08:56 AM
DAE Error-13001 encountered trizzy Pro Tools Software (Win) 2 05-04-2013 07:38 PM
DAE Error-13001 encountered trizzy Getting Started 1 05-03-2013 03:51 AM
DAE error -13001 on PT 8.0.4 for W7 astrojed Tips & Tricks 0 09-15-2012 03:16 PM
