Error -1125...
Hey,
Been having a few issues with one of our rigs in the past couple of hours...started off with the second DA popping and clicking quite badly while showing it was locked to wordclock fine, (all other converters locked to the same source and working as normal) I have tried switching the converter for another and plugging them up different ways with the digilinks but the problem always stayed with outputs 17-32. These outputs have been plugged into each different HD card, still with the same problem on all. ...Now, unfortunatly, pro tools wont boot at all, coming up with DAE -1125 error, which i have had in the past but has always been fine after a reboot, not this time though. We're using a quad 2.5 ppc G5 Pt 7.3.1 Digidesign Expeansion Chassis HD3 Accel 3x Apogee AD16x 4x Apogee DA16x I have tried the same computer with our other expansion chassis (HD3 Accel w/prism converters) and it all works fine... any ideas?? thankyou!! Rich |
Re: Error -1125...
anyone got any ideas?
Were having the smae problem here. pthd 7.3.1cs5 trashed pref's rebooted etc...but still get DAE error -1125 on startup thanks joel
www.joelfountain.com |
Re: Error -1125...
You should contact tech support by phone for assistance with this. It may be due to a timing reset issue, in which case we would swap out your cards.
Does Digitest give the same error? |
Re: Error -1125...
I have the same 1125 problem, how do I contact you guys? Friendly regards Erik |
Re: Error -1125...
Read the thread above yours the "help us to help you" part. then present all the information here and people can help Chris
Re: Error -1125...
I have an apogee rosetta 800 and a Apogee 16x AD and i was getting this message
Made sure all my cables were snug and re-booted the apogees while the comp was on and tried opening pro tools again and it seemed to fix the problem |
DAE errors 9161 9031 1125 | qwertyuiop | Pro Tools TDM Systems (Mac) | 5 | 04-16-2011 06:48 AM |
Strange DAE -1125 error with Waves L316 Multimaximizer | gerax | Pro Tools TDM Systems (Win) | 1 | 04-06-2008 01:35 PM |
dae error -1125 when launching pt | Bryan Cook | Pro Tools TDM Systems (Mac) | 2 | 07-25-2007 08:05 AM |
DAE -1125 hardware issue? | James Drake | Pro Tools TDM Systems (Mac) | 0 | 05-22-2007 03:24 AM |
Buss error,Address error,ilegal instruction,error type 10 | KasticK | Pro Tools TDM Systems (Mac) | 1 | 02-08-2003 05:49 PM |
