Old 11-05-2007, 04:36 AM
allstaar's Avatar
allstaar allstaar is offline
Default Next/Previous Sample in Structure.
This may well be a dumb question, but I've been trying to figure it out for some time without success so bear with me.
When I load a sample into a zone in structure, next to the select zone field there are some up and down arrows that say next and previous sample. I assume these should allow you to step through the samples in a folder, is this the case ? It doesn't work on my system, the sample remains the same wether I click next or previous.
The sample I have loaded is the first snare sample in a folder containing many snare samples.
Many thanks,
Allstar.
Old 11-05-2007, 06:38 AM
allstaar's Avatar
Default Re: Next/Previous Sample in Structure.
After messing around some more, it appears the Next/Previous buttons are not what I'm looking for.
They allow you to select zones not samples.
To be clear, this is what I want to do ;
Make a new patch, load a snare sample in from my library snares folder.
Trigger that snare from a midi track
Set protools playing then flip through the snares in that folder until I find the one that sits best in the track.
Old 11-05-2007, 07:04 PM
If these samples are indeed your own, you can as you'd probably know audition these in either Workspace or the Structure Browser. If these samples are encrypted, Structure doesn't audition samples in the way Workspace works, they need to be loaded. However, you can assign Keyswitches to each and every snare sample and mirror this in the Timeline.
filosofem
Aaron Mulqueen - 001 HD Native
Old 11-05-2007, 11:59 PM
allstaar's Avatar
Thanks for the reply Filosofem.
Structure's browser has a speaker icon that lets me audition samples when I click on it, but this isn't what I really need.
I want to program a snare pattern ( with an arbitrary sound to start ) then while that pattern is playing change the sound with a simple up and down function to step through sequentialy the samples in the folder.
It's a function that other soft samplers I've used like LM4 and Kontakt have and is incredibly usefull when trying to find the right kick, snare or whatever that sits just right in the track.
Infact, so hooked on this way of auditioning drum sounds am I, that if Structure can't do this I'll probably have to go back to Kontakt, which would be disapointing as Structure's integration into Protools is better.
If anyone knows how to do this, I'd be very, very grateful to know.
Old 11-06-2007, 01:36 AM
allstaar, as I was hinting at, to my knowledge, Structure isn't capable of auditioning samples in that manner. However, you can cycle the pattern and use Keyswitching, though it is an extra step than that of other computer-based samplers that you are accustomed too.
...and yes, you are right, Structure does have a number of shortcomings, currently.
filosofem
Old 11-06-2007, 11:26 AM
allstaar's Avatar
Drat!
That's a shame.
The key switching thing is a decent work around, but as samples are often added to my library, I'd have to constantly update the patch in Structure.
I really want to just work with one virtual sampler as they are ( by nature ) complicated and I'd rather not expend grey cells being proficient with more than one.
Oh well, maybe an update to structure will include this way of auditioning.
Thanks all the same filosofem, much appreciated.
Old 11-07-2007, 06:30 PM
allstarr, this might be of interest to you: Pro Tools 7.4
Ability to preview audio in DigiBase browsers in tandem with session playback
filosofem
Structure won't play the whole sample. zigzawya Virtual Instruments 5 10-12-2011 11:45 AM
Structure 1.1/Structure Free Sounds/Sample folder DTheone Virtual Instruments 9 03-29-2011 06:25 PM
How do you load a .big sample in Structure? David Penick Virtual Instruments 2 01-29-2009 10:56 PM
I want Structure to be able to reverse a sample. gwiz31 Virtual Instruments 4 06-11-2008 10:00 PM
Sample Library, Structure or not ? Larsen2 Virtual Instruments 1 01-04-2008 11:02 AM
