Old 09-01-2007, 09:47 AM
j20056 j20056 is offline
Default DDR2 or DDR?
I use a P5GCD ASUS Mobo, but I need more RAM. Currently, I have 2x1GB DDR2, but I need to go up to 4GB or more, because the Andy Johns BFD plugin requires more than 2GB of RAM to load the kits.
Unfortunately, my Mobo can only handle either 2x1GB of DDR2, or 4x1GB or DDR. So it seems that DDR is the only option for this board. The manual says that I would damage the board by using both DDR and DDR2. By removing the 2 DDR2's and buying 4 DDR, I could get up to 4GB.
But is DDR much worse than DDR2? Should I use this as an excuse to get a new PC altogether?
Digi002 Rack
Mac Pro 8-core 3Ghz
8gb RAM
3X 500GB 7,200 SATA DRIVES
OSX 10.5.7
PTLE 8.0cs3
Old 09-01-2007, 11:22 AM
rickthestick rickthestick is offline
Default Re: DDR2 or DDR?
Do you have the right model number?
DDR and DDR2 are not interchangable. Your motherboard uses one or the other.
Check your manual, if you don't have it go here: Asus and check the manual.
Old 09-01-2007, 11:31 AM
My motherboard takes both, *believe me* I checked. In fact, I found out the hard way by buying another 4gb of DDR2, and figuring out that the 4 available memory slots unused were not for DDR2 but for DDR. The manual says I can't use both DDR and DDR2 at the same time. So I can do a max of 2x1gb of DDR2 (my current setup), or 4x1gb of DDR, which I must do to get teh AJ lits to load in BFD. That's why I was inquiring whether DDR is an OK choice, or whether it's time yo upgrade to a new machine.
Digi002 Rack
Mac Pro 8-core 3Ghz
8gb RAM
OSX 10.5.7
PTLE 8.0cs3
Help finding DDR2 4GB sticks! blizzard General Discussion 8 03-11-2011 11:45 AM
AMD 64X2 - MSI K9VGM - 2GB DDR2 800MHz - BUFFER ERRORS! Table Syrup Records 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 07-19-2007 07:49 PM
How can I optimize the useage of 4 gigs of ddr2 667 Filmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-01-2007 11:39 PM
2GB DDR2 or 3GB DDR ? MarkusB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 04-16-2007 10:44 PM
