Old 07-17-2007, 08:15 AM
Ericsov Ericsov is offline
Default mbox mini latency
how do i eliminate the latency when recording w/ mbox mini?
Old 07-27-2007, 11:52 PM
Scorpio253 Scorpio253 is offline
Default Re: mbox mini latency
Bump
MBox 2 Mini
Pro Tools 7.4 - MPTK
Sony VAIO VGN-NR120E
Windows Vista Home Premium
Old 07-28-2007, 12:25 AM
Shan's Avatar
Shan Shan is offline
Mbox 2 Mini gives you the ability to monitor
your analog input signals while recording, without
the delay incurred by A/D/A converters and
host-based processing.
This zero-latency analog monitoring is controlled
with the Mix knob, which you can use to
blend and adjust the monitor ratio between
Mbox 2 Mini analog inputs and Pro Tools playback.
To listen to just the source input signal, turn the
Mix knob fully left to Input. To listen to
Pro Tools output only, turn the knob fully right
to Playback.
The output from the Mix control is routed directly
to the Mon Out (Monitor Outputs), and is
mirrored in the Headphone output.
This ability to blend and control the relative levels
of Pro Tools playback and latency-free live
analog inputs can be particularly effective when
overdubbing.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 07-28-2007, 12:31 AM
Shan's Avatar
...you'll also have to hit the mute button on the track you are recording.
Shane
Old 07-28-2007, 01:15 AM
Thanks a lot. I appreciate it!
MBox 2 Mini
Old 07-28-2007, 01:16 AM
Shan's Avatar
No prob.
Shane
Old 08-05-2011, 02:04 PM
scherer.cc scherer.cc is offline
Thanks for your advice! However, I have a question/concern... when I do the same, and turn the "Mix" knob hard left, using a mono track to record a simple vocal line with a mic... the input is only heard in the left ear of my headphones! Is there any solution to this?? Something about that just doesn't seem right.
Old 08-05-2011, 06:03 PM
The Weed's Avatar
The Weed The Weed is online now
Do you have a stereo master track for playback? If it's only playing back from a mono track...
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 07-18-2012, 04:56 PM
WernerF WernerF is offline
I'm having the exact same problem with the latest mBox mini on P Tools 10 on a MacBook Pro. Is there a solution to this?
Old 07-18-2012, 07:45 PM
albee1952 albee1952 is online now
Usually this is the "newbie" mistake of recording a mono source(like a vocal or acoustic guitar) to a STEREO track. Record to a mono audio track.
Asus x99, Intel i7 6800K, 32 gig DDR4, GeForce 750 Ti, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs and Midas..............................
www.capricornsoundworks.com
Sudden latency with Mbox 2 Mini steve.mastr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-01-2009 03:03 PM
MBox 2 Mini Mix Latency my808 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-06-2007 03:11 AM
Mbox Mini-Me Monitoring Latency Larue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-27-2004 06:50 PM
mbox + mini me latency issues jvancorduroy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 09-22-2003 07:08 AM
Help !! Mbox +Mini Me latency issue jvancorduroy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-18-2003 10:38 AM
