Old 04-15-2007, 03:38 PM
dm3 dm3 is offline
Default Pro Tools does not support unmapped network volumes?...HELP!
Dear experts...
Hello there...I´m repairing (reinstalling) Pro-Tools LE 7.0 on an HP Pavillion zv5000 laptop. While trying to open my previous sessions from an external E: Drive (not yet specifically formated for audio) it shows "Pro tools does not support unmapped network volumes". I´m unable to open any previous session.
I´ll greatly appreciate your advice on this matter...
dm3
Old 04-15-2007, 03:42 PM
kRokksOn kRokksOn is offline
Default Re: Pro Tools does not support unmapped network volumes?...HELP!
You could try mapping it.
right click "my computer" - select "map network drive" - select the hard drive and assign it a drive letter.
Maybe that works.
Another solution could be using the workspace browser within Pro tools (windows - workspace browser) and see if pro tools sees you drive. If not you should try mounting it within pro tools.
"lyrics, wasted time between solos!"
kiddipalli@simnet.is
syrland.is
myspace.com/kiddipalli
Old 04-15-2007, 06:11 PM
spkguitar's Avatar
This happens sometimes if you connect an external drive after opening Pro Tools.
Always connect all drives that will be used in PT before opening the program.
Old 01-21-2010, 10:12 AM
tyros tyros is offline
Smile Re: Pro Tools does not support unmapped network volumes?...HELP!
Hi I had the same problem And I called to digidesing support and they told me what I should to do :thet says pro tools does not support unmapped network volumes". this message appers when you open pro tools after you plug in a flash memory or external hard disk you have to restart your computer and first plug in your flash or hard disk and then open pro tools. I did this and my pro tools works perfectly I hop this hel you too.and other thing pro tools does not support any version of windows vista in 64 bits I had this system before and I had too much problems with messages like THe buffer engine or and my 003 rack like audio clock and my 003 did not work untill I change to "windows vista ultimate 32 BITS"pro tools only works with "windows vista bussines or ultimate but 32 bits"o I reccomend you guys chek what systems you have and if you have 64 bits pro tools never will works perfectly.(sorry for my inglesh but I just want to help because I was looking about for 6 month looking for the solution to all my problems with pro tools and this was only I had to change to 32 bits.!!)ok my frends Thankx.!!
Unmapped Network Volumes???? snookjohn Pro Tools TDM Systems (Win) 1 07-01-2010 08:14 PM
why do I get a "protools does not support unmapped network volumes? oterrero Pro Tools SE and Essential (Win) 1 03-18-2010 09:53 AM
Pt will not support unmapped network volumes sixmoons Pro Tools M-Powered (Win) 2 11-15-2006 09:23 AM
Error - Unmapped Network Volumes lovett 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-25-2006 10:14 PM
ProTools does not support unmapped network volumes Matt Whritenour 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-20-2005 06:28 AM
