Old 03-05-2007, 11:38 AM
donrey donrey is offline
Default AES to Mbox 2 Pro Spdif
Does anyone know the easiest/best way to bring in an AES signal to an Mbox 2 pro. I've been researching and it seems like I should be able to connect a Digital XLR to RCA cable. However, I have been reluctant to test it out in fear that it will damage the Mbox 2 Pro. Any ideas? suggestions? anyone got this working? would it be best just to buy one of those HOSA AES to Spidif signal converters?
I am attempting to bring in the AES signal from a Liquid channel to an Mbox 2 Pro. We currently use the liquid channel via AES on an HD system through the 192 and we are more than happy with the LC's converters. I believe I should be able to get the same quality from the Mbox 2 pro if I'm able to bring in the signal digitally bypassing the Mbox 2 pro's A/D converters.
Old 03-05-2007, 12:28 PM
letrev's Avatar
letrev letrev is offline
Default Re: AES to Mbox 2 Pro Spdif
You can use AES to S/PDIF adapters. I purchased one a while back in order to connect my Mbox to a Benchmark DAC. Works fine.
Steven Vertel
Mixing / Mastering Engineer
High Rock Records & Studio
NYC
http://highrockrecords.com
Old 03-05-2007, 01:04 PM
can you tell me which adapter you purchased and where it was purchased? I have seen that HOSA makes a box but I'm looking at other options.
Old 03-06-2007, 06:04 AM
Bugly Bugly is offline
just make up a lead
XLR to spdif
done it a million times
go for it
Mbox 2 Pro Spdif davidlestudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-19-2009 06:39 PM
mbox spdif nivelle2000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-21-2006 11:53 AM
spdif out on audigy to spdif in on mbox? CrAkD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-06-2006 08:48 AM
Mbox and Spdif I/O Thresholdproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-20-2004 06:01 PM
using spdif with mbox wrangler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-06-2004 01:29 PM
