Old 03-02-2001, 09:53 AM
NuBus NuBus is offline
Default Plugin Authorization w/ProTools 5.1
It seems as though the new Bruno/Reso plugins don't reconize my old Authorization? My other plugs seem to work fine?
Thanks
NuBus@att.net
<BLOCKQUOTE><font size="1" face="Arial,Helvetica,sans-serif">quote:<HR>Long Live Nubus and TI<HR></BLOCKQUOTE>
Old 03-04-2001, 03:58 PM
Default Re: Plugin Authorization w/ProTools 5.1
I have been woring on this and have realized that I had authorized Bruno Reso with the Challenge Response option. Should I try to use the floppy to reauthorize if I can find it? I remember having problems with the USB floppy. Or is there something I have to do in order for the New Plug In version to reconize the old Challange Response code?
Thanks
NuBus@att.net
Old 03-05-2001, 09:50 AM
DigiTechSupt's Avatar
Challenge/Response authorizations for plug-ins are disabled in PT 5.1. Therefore, you will need to re-authorize Bruno-Reso with a floppy.
-Currently, the only supported devices for the B&W G3 andG4 is the Imation SuperDisk, the Newer Technology Udrive and the VST Floppy Drive (model FDUSB-M).
The Udrive requires version 1.0 of its drivers available at:
http://www.newertech.com/software/drivers/index.html
The Imation SuperDisk requires these drivers:
-USBSuperDiskClassDriver v3.3
-USBSuperDiskUTDriver v3.3
both of these extensions are available (as a single download) from the following URL:
http://www.superdisk.com/sc/sc_dl_um.html#1
The VST Floppy Drive requires the following driver:
-USB Floppy Support 2.1.5 — installed by the VST CD and (v2.1.6) is available at:
http://www.vsttech.com/vst/drivers.nsf/Default
All drives require the following extension:
-USB Floppy Enabler 2.1f1 (or later) --- available at:
http://www.paceap.com/download.html
Brent
Avid Audio Tech Support
Support FAQ
Old 03-06-2001, 05:32 AM
Snitz Snitz is offline
Brent -
Do you mean this for ALL plugs, not just Digi's? Some of us out here have relationships with developers, are using legal NFR versions authorized via challenge/response, I'm sure there are a bunch of scenarios... I understand that you want to stop the stealing etc., but this is not a very well thought out way to go about it. Just my 2 cents...
Old 03-06-2001, 08:04 AM
InSights7 InSights7 is offline
Originally posted by Snitz:
Brent -
Not to worry. I have several challenge/response third party plugins. They all work without a hitch.
Dan Matthews
InSight Sound Recording
Dan Matthews
Loveland, CO
(970) 663-1650
InSight Sound Web Page
Old 03-06-2001, 02:46 PM
Thanks Dan, once again you've got the right info....
Andy
Old 03-07-2001, 05:10 PM
jeffro's Avatar
jeffro jeffro is offline
Correct, just digi Plug-Ins have been changed.
Old 03-25-2001, 04:11 AM
midigeek midigeek is offline
<<<-Currently, the only supported devices for the B&W G3 andG4 is the Imation SuperDisk, the Newer Technology Udrive and the VST Floppy Drive (model FDUSB-M).>>>
Also the Imation Floppy disk only drive works. It is also around $99 like the Newer Tech uDrive.
MS
Plugin Authorization help. snorgit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-31-2007 07:42 PM
plugin authorization tom devilution 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-03-2007 07:11 AM
plugin authorization yachty 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-22-2006 06:06 PM
transfer plugin authorization jarrett Post - Surround - Video 1 09-03-2002 09:33 AM
The Ins and Outs of Plugin Authorization GrooveJungle Pro Tools TDM Systems (Mac) 0 07-19-2002 08:46 PM
