Old 09-30-2008, 09:04 AM
StefB's Avatar
StefB StefB is offline
Default Re: tascam dsm 7.1
I have the same problem - except I am 11000 miles away - is there anyone who can tell me which of the caps I need to replace???
Thanks
Stef
Old 09-21-2009, 03:56 PM
Floydio Floydio is offline
Wow, a little bit behind the times with my unit going down but it seems... that is what happened.
Stopped passing audio the other day, not even test pink. Then on a reboot today, had the FPGA configuration fault mentioned above.
Guess we'll see what Tascam/Teac does with these old units...
Old 09-22-2009, 02:36 AM
StefB's Avatar
Replace with C-66 on Main PCB and C-14 on Power Supply PCB will fix the problem.
For more info - pm me albertyn@iafrica.com
Old 10-09-2010, 02:21 PM
Studio 192 Studio 192 is offline
And another year goes by on this topic!
Hi all;
I recently picked up a Tascam DSM 7.1 with this similar error in hopes to fix the problem myself. I’ve done some DIY cable builds but only a couple PCB fixes. I got it all opened up and found both capacitors. C-14 on the Power Supply PCB looks fairly easy as contacts are clearly exposed with plenty of room. I’m also not very good at reading components and after some web searching I was still a little unclear. C-14 on the PS PCB looks self-explanatory reading - 1000μf 6.3v +105ºC. I got a little confused on C-66 on the Main PCB, it reads 1?, 47, 25V (see pic). I can only assume 47μf 25v but have no idea what the 1? means. After perusing mouser’s capacitors, there are also tolerance, ESR, and type to consider and I really don’t know what I should choose or look for.
Basically I’m looking for any hints, tips, or advice on how to tackle this fix. Would the local radio shack have the components I need or should I use mouser / digikey? As far as C-66 goes I’m not to familiar with the mounting/housing it sits in. Are these snap-in type or solder type? How might I go about getting it out?
Any help is greatly appreciated and I thank you in advance.
http://picasaweb.google.com/lh/photo...eat=directlink
Old 10-09-2010, 03:17 PM
Postman Postman is offline
That is definitely 47uf/25v. I have no idea with the 1-something means but don't worry about it.
I know you want to save money, but if replacing those two does not work you should just ship it to the service center in Montebello, save yourself some grief.
  #16
Old 10-18-2010, 11:51 AM
Pythagor Pythagor is offline
Hi
i also have similar problems with my unit. anyone can advice a an authorized servicer? i asked Montebello but they do not repair products sold not in US
thanks
Leo
  #17
Old 10-18-2010, 01:20 PM
That is unfortunate. Have you sent an email to Tascam directly? Tascam dot com is the home page and I see Repair as a category under Support.
  #18
Old 10-18-2010, 01:33 PM
It leaded me to Montebello. Cannot use them as i said.
  #19
Old 10-18-2010, 02:47 PM
Craig F Craig F is offline
Teac owns Tascam so maybe something here:
http://www.teac-instruments.com/Distributor.html
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
HTML code is On
Tascam DM-32 guitar486 Pro Tools M-Powered (Mac) 7 06-19-2008 07:45 AM
Tascam DM-24 with PT TDM mix + AUDIOSFX Pro Tools TDM Systems (Mac) 10 06-06-2003 08:15 PM
Tascam DM-24 and 001 studiotony 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-29-2003 03:22 PM
Tascam US-428 cnelson87 Digidesign Hardware & Software 8 03-24-2001 04:37 PM
001 + Tascam MDM? BHeller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-10-2000 08:59 PM
