Old 12-16-2006, 08:01 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Mbox 2 Firmware v1.43 - DAT Issue Fix
Firmware updaters available for PowerPC Macs, Intel-based Macs, and Windows XP:
http://www.digidesign.com/index.cfm?...4&itemid=24364
The folowing issue is fixed with Mbox 2 Firmware Updater v1.43 for Mac OS X and Windows XP:
Fixed: Certain DAT Decks Lock To The Wrong Sample Rate When Recording From Mbox 2 (Item #83265)
  • When attempting a 48kHz sample rate DAT recording via the S/PDIF input, some DAT machines would either show a clock error or lock at a 44.1kHz rate, resulting in a DAT recording that would later play at the wrong speed.
Mbox 2 with firmware v1.43 is backwards compatible with any version of Pro Tools LE for Mac OS X and Windows XP that supports the Mbox 2 (Pro Tools LE 6.8.1 and higher).
Administrator
Old 12-19-2006, 03:47 AM
danander11 danander11 is offline
Default Re: Mbox 2 Firmware v1.43 - DAT Issue Fix
I followed the link, read the instructions, and attempted to update teh firmware in my MBOX2. after starting the updater program, I plugged the MBOX2 in, and when it powered up, I selected UPDATE FIRMWARE. After pressing the button, it paused for about 15 seconds then gave me an error message stating that the file had not been downloaded... I waited a few minutes, no change. I unplugged the MBOX2, shut down the program, rebooted the computer, and tried again.. same result.
I shut everything down again, and this time after restarting, the MBOX2 would no longer power up when plugged in.. I tried other cables, and other USB ports. Anyone else have issues like this?
Thanks.
Danny
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 12-19-2006, 04:39 AM
Phil Jeffers Phil Jeffers is offline
Unplug your MBox 2 while downloading the driver, unzip the driver, then launch the update, then plug-in the M Box 2, then press the update button and it should work. The same thing happened to me, I double checked the read me, and this order (and perhaps speed at which you plug in the cable) has a bearing on the firmware update.
Old 12-19-2006, 05:44 AM
I did that originally... and a couple of times since.. Whenever I tried it, it gave me a FIRMWARE UPDATE FAILED NO DEVICE FOUND message.
Now I get that message with everything. It just does not power up when I plug the USB cable in..
I may go back to PTLE 7.1 and try again. I have uninstalled and reinstalled PTLE 7.3 twice with no affect either..
I'm stumped.
Thanks however.
Danny
Here I am,
Hobo Shave!
Old 12-20-2006, 03:32 PM
Another update for those following this...,
I installed the stand alone drivers onto my laptop and connected the Mbox2 to it with the same result. All that I can come up with is that whilst downla\oading and installing the newer version of firmware, something critical sh*t-the-bed and now it refuses to initialize.
Is anyone aware of a way to force the Mbox2 into a default or test mode?
Thanks once again.
Danny
Here I am,
Hobo Shave!
Firmware Issue MBOX pro AVID will charge for repair flautista FireWire & USB Audio Interfaces (Mac) 0 11-07-2013 03:21 PM
MBox Pro 3 constant firmware update issue (w/ a twist...) leftalive macOS 3 04-10-2013 02:56 PM
Command 8 Firmware issue Sixstringer7 ProControl, Control|24, Command|8 0 11-18-2009 08:11 PM
002 firmware issue albee1952 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-17-2009 01:19 PM
Mbox 2 Firmware v1.43 - DAT Issue Fix Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-16-2006 08:00 PM
