Avid @ NAMM 2018
Old 08-27-2006, 07:39 AM
mastermorris mastermorris is offline
Default TPKD driver????
When I boot up protools it says that I have to update the TPKD driver?? What is this and how do I update it?
Rob
Old 08-27-2006, 07:49 AM
BFrederick BFrederick is offline
Default Re: TPKD driver????
Go to paceap.com and download the latest driver for your system. This is Interlock driver-related. I had the same problem after installing Time Shift onto PTMP and this download resolved the issue.
BRENT FREDERICK
Musical Director, Arranger, Pianist
PT10, MOTU Audio Express, 10.7.2
http://www.BrentFrederickMusic.com
Old 09-05-2006, 09:22 AM
Tim1 Tim1 is offline
I had the same problem & solved it by reinstalling PT.
Tim
Old 09-05-2006, 03:20 PM
Parisstudio Parisstudio is offline
Yes, just install the latest Pace update.
Old 09-05-2006, 03:21 PM
D/L Pace update
Old 09-05-2006, 07:59 PM
sunburst79 sunburst79 is offline
I'm having the same problem after installing the Music Production Toolkit. I've downloaded the latest drivers from the PACE site, I followed the llnk from searching the Digidesign site downloaded those drivers from PACE . All of my iLok drivers are up to date... I've reinstalled the MPTK, the Factory Pack the Ignition Pack and all off the other Plugs in the MPTK (TL space etc...). Any body have any idea what to try next? I'm running XP home.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 09-09-2006, 02:08 PM
Well I went back and uninstalled everthing DIGI on my system, I reinstalled everything all over again, Protools 7.1, Ignition Pack, The MPT, TL space ETC. Restarting the the System and Relaunching PT each time and everything is fine untill you install the Free Time Shift Plugin, Thats when The "Updated TPkd driver and reboot needed" Error code shows up. The Signal Tools Plug that was released at the same time is fine. Anybody have any other ideas on eliminating the Error Message when launching Protools?
SB79
Scott
Core 2 Specs Page
Old 09-09-2006, 11:49 PM
Read what everything says above. Go to www.paceap.com. Download the latest drivers for your operating system.
BRENT FREDERICK
Old 09-19-2006, 12:23 PM
I just thought I would post an update becuase it may help someone else.
After completely reloading ALL of my DAW software (Accross 2 partitions-Xtra fun!) I had determined that it was specificly the TIME SHIFT plug causing the TPkd Driver error.
I had of course installed the updated TPkd Driver from PACE several times to no avail before comepletely reinstalling all of My DAW software, Plugins, ETC.
The solution (At least in my particular case) was to run the PACE installer again. Select REMOVE instead of INSTALL. Run the PACE installer Again select INSTALL and reboot.
You must remove the old driver completely before you install the updated driver.
Hopefully this saves someone some time.
Scott
Core 2 Specs Page
Tpkd Driver??? MYFault101 Pro Tools M-Powered (Win) 6 07-01-2006 03:03 AM
TPkd driver pinstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-19-2005 06:16 PM
Updated TPkd driver? eldusto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-13-2005 02:06 PM
PLZ Help: Getting message Updated TPkd Driver rcrell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-09-2005 09:04 AM
TPkd Driver filosofem 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-08-2005 01:04 AM
