Old 06-29-2006, 12:43 PM
RogerJeep RogerJeep is offline
Default send/return
I am using 002 with 7.1. I am trying to use an external reverb unit. Here is how I am routing the device. send analog output5, insert analog input 4. When I do this I get a very loud noise. What am I doing wrong. I have tried other outputs and inputs as well as other devices they all are making the same noise. Please help.
Thanks
Old 06-29-2006, 12:54 PM
spkguitar's Avatar
Default Re: send/return
It would be easier to help if we knew what reverb unit specifically.
Old 06-29-2006, 03:08 PM
Create an Aux Track, set the input to an unused Bus (say Bus 3) -- plug the hardware like so:
002 4 Out -> Outboard Effect In
002 4 In <- Outboard Effect Out
On the Aux Track where you normally insert a plug-in.. select I/O 4
To send to the effect, create a post fader send (Bus 3) on the track you wish to effect (say the vocal) -- the effect return level will come back on the Aux Track. Set your effect device to 100% wet. Ctrl+click on the SOLO button of the Aux Track to solo isolate it.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 07-01-2006, 09:07 AM
GW GW is offline
...and the reason for that is f.x. if it΄s a unit with a S/PDIF IO, I would recommend that solution insted. Many modern reverbs has a S/PDIF that you can connect to the Digi 002 with two 75 Ohm cables and you get digital all the way without D/A and A/D conversion back and forth...
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8,
Digi002 Fact., Logic X|FCPX|Motion
Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune
VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile
Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix
c24 send return to ext effect BMSS ICON & C|24 4 04-07-2011 03:36 PM
Best way to set up reverb send and return? obidon Pro Tools TDM Systems (Mac) 2 11-10-2010 04:25 PM
Bus: Send / Return bassbuddy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-31-2005 10:51 AM
can the 001 send and return while mixing? Shaun.O_123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-04-2001 02:02 PM
Send and Return Spam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-14-2000 10:30 AM
