Cubase not recognizing 002r ASIO drivers
Recently found the need to run cubase se on my home 002r system. I have installed the drivers from the ptle 7.0 disk but cubase won't recognize them. Any suggestions? I was going to try older PT ASIO drivers but have been unable to find them on the download site. Maybe try uninstalling PTLE? Thanks, jon
Re: Cubase not recognizing 002r ASIO drivers
The Digi ASIO drivers are not available as in option under "Devices > Device Setup" in Cubase?
Nope they aren't showing up for some reason. I installed the ASIO from the 7.0 install disk, restarted, opened cubase and no go. I had heard someone dropped the digi ASIO .dll file into a cubase folder and it worked for them. Tried that, (in all folders) still didn't work. God forbid I have to buy a fireface
Also tried uninstalling PTLE and just installing the drivers. Also reinstalled cubase a couple times. Nothing.
In both Cubase LE and now CB SL 3, the Digi ASIO, installed in its default location, shows up as an option in Cubase Devices > Device Setup. |
Gottcha, I'm starting to think it is because I'm running SE 3. I've come across a few posts on both boards where SX and SL running system got it to work after a little trouble, but none of them refer to SE 3. Might be that steinberg doesn't keep SE 3 up to date. Seems there are patches available for SX and SL that aren't there for SE.
Thanks, jon |
Help with ASIO Drivers for 003 rack - Cubase even not recognise..... | gregers123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-18-2008 05:43 PM |
digi001, ASIO drivers, Cubase | Andi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-09-2006 12:13 PM |
Problems with ASIO drivers, Cubase SX3 with 002r | fog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-12-2005 07:53 PM |
anyone using MBOX ASIO drivers with CUBASE/LOGIC? | tom_h | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-15-2003 10:43 AM |
no asio drivers to cubase and a mixer to windows98? | omen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-19-2001 05:39 AM |
