Old 11-22-2005, 11:21 AM
djd2 djd2 is offline
Default midi interface USB for Laptop what works?
I have a problem with my Mackie Control and XT (extender) I have an m audio 2x2 connected to my laptop. I am getting crashes in protools with the MCU hooked up. I recently noticed that I get a "ran out of token" errors. This lead me to a bit of info mainly suggesting that the m audio interfaces don't work well with the mackie and protools. One suggestion was to use a joystick port midi interface but that won't work with my laptop. I have tried the token.txt fix and even the m-audio midifix to no avail. Other than this my system is performing well, if I use the mackie MCU connected to the Digi002 midi in I have no trouble.
The question is....who has an 002 with a mackie MCU and an extender connected to a usb port and has it working. If you have an M audio 2x2 what did you do to make it work or if you have something else what is it?
Thanks!
Dave
Old 11-23-2005, 06:13 AM
Default midi interface for laptop suggestion
Bump
I know I am not the only one that has had this problem....
Old 11-23-2005, 06:18 AM
bb_aus bb_aus is offline
Default Re: midi interface for laptop suggestion
i dont have an MCU but i have read other having similar problems. have you done a search?
get an edirol interface it should solve your problem
Old 11-23-2005, 06:34 AM
Thanks for the response. I have searched and found discussions on the web and here in the DUC about similiar probs but no one has mentioned what interface works. I don't want to keep spending money on interfaces until I find one that works as most places don't offer money back guarantees around here. I was thinking about the edirol I'll look into it.
Dave
Old 11-23-2005, 08:08 PM
any good dealer will let you return it within about a week if it doesnt work for you. just check before you hand over your cash
as far as i know the problems have only come with certain Midiman/M-Audio interfaces and the edirols are fine. the only way to know for sure is to try one out
I think my laptop it's not supported but works OK! HITMASTER Pro Tools M-Powered (Win) 0 07-27-2010 12:27 PM
MIDI Interface that works with Digi 001? Reg. MIDI 4 10-10-2005 02:45 AM
Non-USB MIDI Interface for Laptop? Chucky MIDI 2 02-26-2004 12:23 PM
Non-USB MIDI interface for laptop? Chucky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-23-2004 11:52 AM
MIDI TIMEPIECE AV with USB interface works fine into G4 with DIGI001/PT le? Renato 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-08-2001 03:38 PM
