Patch Names
is it possible to SEE my Triton or Motif Patch Names in PT LE
Is this adressed in PT7 |
Re: Patch Names
Patch Names Pro Tools supports XML (Extensible Markup Language) for storing and importing patch names for you external MIDI devices. Pro Tools installs MIDI patch name files (.midnam) for the factory default patch names of many common MIDI devices. These files reside in directories, sorted by manufacturer, in Program Files\Common Files\Digidesign\MIDI Patch Names\Digidesign (Windows) and /Library/Audio/ MIDI Patch Names/Digidesign (Macintosh). To import MIDI patch names into Pro Tools: 1 Verify the MIDI Device definition in the MIDI Studio Setup (Windows) or Audio MIDI Setup (Macintosh). 2 Verify the MIDI track’s output is correctly assigned to the MIDI device. 3 Click the MIDI track’s Program button. 4 In the Patch Select dialog, click the Change button. 5 In the Open dialog, navigate to Program Files\Common Files\Digidesign\MIDI Patch Names\Digidesign\<name of manufacturer> (Windows) or /Library/Audio/MIDI Patch Names/Digidesign/<name of manufacturer> (Macintosh) and select the MIDI Patch Name file (.midnam) for the MIDI device. 6 Click Open. 7 The Patch Select dialog will be populated with patch names and the Patch Name Bank pop-up menu will appear in the upper left hand corner of the window. Once patch names have been imported into Pro Tools, they will be available for that MIDI device in all sessions. To clear patch names: In the Patch Select dialog, click the Clear button, and click Done. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Re: Patch Names
thanks...ive been away awhile
anyone know why when i switch voices like say from a bass to key and then stop>start the voice reverts back |
Re: Patch Names
Re: Patch Names
I don't have a change button. Wrong settings?
Mbox ProTools LE 7.0 Show a little patience! I'm female & blonde |
Re: Patch Names
MaLa, patch name support in XP was introduced in version 6.7
Re: Patch Names
OK. That makes me kind of happy.
Next question: What is hui and what can appear there?
Ground Control patch names = 11R patch names? | drebin | Eleven Rack | 5 | 11-23-2010 01:54 PM |
OMS Patch Names | Tom Pollock | Pro Tools TDM Systems (Mac) | 13 | 07-28-2000 09:47 AM |
PT5 & OMS Names Manager (MIDI patch names) | Baron Von Deca | Tips & Tricks | 0 | 02-17-2000 04:55 PM |
OMS PATCH NAMES? | studiocenter | Pro Tools TDM Systems (Mac) | 2 | 02-17-2000 01:12 AM |
Patch Names on PT 5.0? | studiocenter | Pro Tools TDM Systems (Mac) | 2 | 02-08-2000 08:42 AM |
