Old 08-26-2005, 11:07 AM
sleepwalk sleepwalk is offline
Default Pro Tools M-Powered, Rewire, and VST instruments
I asked the Scarbee guys (that make vintage keyboard soft synths) if their stuff worked with ProTools M-Powered. He said it works in ProTools with Rewire. As I understand, ProTools is a "Rewire enabled application." So this would allow you to play and sequence VST instruments. So, I thought that ProTools cannot play VST instruments, but since it comes with Rewire, actually, it can ? Is that right ? Someone please explain....thanks.
Old 08-26-2005, 11:29 AM
spkguitar's Avatar
Default Re: Pro Tools M-Powered, Rewire, and VST instrumen
Protools can not use the VST format in it's native form, no.
"Rewire" is a program to program link developed by Propellerheads. It takes the place of hardware wiring (MIDI cables and audio cables) between two programs. It works on a "host"/"client" sort of basis, and Pro Tools is a rewire "host". Other programs, such as Propellerheads Reason, Sony Acid, Ableton Live can all function as rewire "clients". Linking programs this way also links the transports of the pograms; hit start in the rewire host and the client starts at the same location and plays along in sync. Some rewire clients have the cabablities to run VST instruments. So, you could technically run VSTi (instrument) plugins in this fashion, say with Ableton Live rewired to PT and a VSTi loaded in Live. With the current rewire specification, MIDI and audio only flow in one direction (MIDI out from the host to the client, and audio in from the client to the host), so unless the audio you are trying to process resides on the client, you will only be able to use VSTi, not regular audio manipulation VST, using rewire.
The more popular way to run VSTi and other VST plugs in Protools is by using the VST-RTAS adapter from FXPansion. This handy (and well worth the money IMHO) piece of software "wraps" almost any VST plugin so that it can be used within protools in it's native RTAS plugin format.
Old 08-26-2005, 12:45 PM
The FXPansion software sounds like a fine solution. Thanks for all the info, I really appreciate it !
Old 08-26-2005, 02:47 PM
lionel payet lionel payet is offline
Unfortunately, when using Live as client with PT or any other host, VST instruments can't be used in the client, it's a rewire limit. I
http://www.l2pmusic.com
my ableton doesnt appear in pro-tools instruments as rewire djcalg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 20 05-01-2016 09:17 AM
rewire reason 3 pro tools m-powered violent vickie Pro Tools M-Powered (Mac) 4 05-11-2010 01:56 PM
Reason>Rewire>Pro Tools M-powered michonsong Pro Tools M-Powered (Mac) 0 02-26-2009 08:07 PM
Rewire and instruments track in PT 7.4.2 Bobbers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 06-29-2008 03:29 AM
Virtual instruments and rewire between PT and DP mixaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-22-2005 12:48 AM
