Closed Thread
  #71
Old 02-19-2006, 10:16 PM
theskybeneath theskybeneath is offline
Default Re: Audio Record or Playback Volume Error Info
Hey Guys, I skimmed the whole topic and couldn't see any mention of this, so apologies if it's already been said, but...
This playback volume (in the Workspace menu) issue was easily remedied for me by trashing the folder "DAE Prefs" and the file with "digidesign.plist" in the filename. (i.e. the ProTools prefs file). Before doing so, I couldn't change the volume from "T" to "R", and after trashing those files, it works.
So, you may not have to back-up and reformat!!!
Hope this helps some people.
  #72
Old 03-07-2006, 08:14 PM
cotton cotton is offline
I just purchased a Mac G4 laptop with a 80 gig 5400 rpm internal HD, and am trying to run Pro Tools M-Box 6.9
will the Internal drive handle this? It is saying not an audio record volume
Thank you
  #73
Old 03-08-2006, 03:04 PM
DigiTechSupt's Avatar
Thank you
What OS version are you running? If it's Tiger version 10.4 or higher then you will need to update to Pro Tools 6.9.2 or higher for compatibility.
The internal drives are typically too slow to do more than a few tracks, so you probably will want to get an external drive to record and playback from.
Avid Audio Tech Support
Support FAQ
  #74
Old 04-03-2006, 08:46 PM
kartopolis kartopolis is offline
I keep getting an error message when I try to record new tracks to my
external hard drive. ProTools can read my old sessions, and I can edit
and save existing tracks, but I can't write to it, even though I could
before. The specific message is "can't complete request because of
Assertion in "CNeolnode.cpp", line 1242. I checked Answerbase and it
wasn't helpful...just curious if you've ever encountered this problem
or something similar (oh, I reinstalled PT 7.0 and it didn't work). If
you could help that's be great..lemmee know.
Matt
P.S. I checked in Workspace, and my external (partitioned) hard drive is marked "R", so, unfortunately, that's not the issue.
  #75
Old 04-05-2006, 08:08 AM
Matt
Please start with the steps in the OS X Setup and General Troubleshooting sticky at the top of this forum, specifically those areas on trashing preference and database files.
Support FAQ
  #76
Old 05-20-2006, 10:42 AM
earworms earworms is offline
i've read through this thread, but i don't think my problem has been mentioned. i am trying to record using pro tools LE 6.8.1 on a 15" PB running MacOSX 10.3.9. i want to record to the internal harddrive and it is set to 'R' in the workspace window. when i press record, it does actually start recording and i get a level signal, but when i then stop a message comes up saying: NeoAccess Error. could not complete requested task... this error message also comes up when PT tries to autosafe backup sessions every five minutes. any suggestions? i have previously recorded onto the internal hd without any problems. oh yes, and i have also tried to trash preferences and repair disk permissions to no avail. thanks.
  #77
Old 05-22-2006, 11:05 AM
Support FAQ
  #78
Old 05-24-2006, 05:42 AM
edeast edeast is offline
Please ignore my previous ramblings.... bad day..
In case this helps:
'no audio record volume' error suddenly started appearing in PTLE 6.7 on PowerbookG4 OS 10.3.6, after backing up to Lacie 160G Ext HD. Changing Audio preference from Playback to Record in the Show Workspace window sorted it out.
thanks digi for your patience
  #79
Old 06-21-2006, 05:11 PM
god_within god_within is offline
so im having similar trouble as most people here. ive been using pro tools le 6.7 on my desktop pc, with a lot of latency issues, so i upgraded to a faster and better mac notebook...the macbook, not the pro version tho. its a 2.0 Ghz pentium duo processor and has a gig of ram and is running os x 10.4.6. i installed pt 6.7 and and upgraded to 6.9.2 via the internet download. i got pt to open but i cant save /start a new session b/c neither my mac hd nor my iomega external hd is an audion record drive. so i went into the workspace window and tried to set either drive to audio record. the "V" column both are set to R, but neither one will let me put an R in the "A" column. a message comes up saying that i can not set this drive to audio record because it is not a valid audio volume. i tried all the suggestions on this web site except reformatting, seeing that the mac hd is already set to mac os extended (journaled). i tried repairing permissions. i tried reinstalling and repairing permissions after every download. i even tried restarting between every single install. i tried uninstalling ableton live and reason adapted. so now im at loss. please help. thanks
  #80
Old 06-22-2006, 01:02 AM
bigteeze bigteeze is offline
I'm having the exact same problem...looking for any advice!
Closed Thread
workspace - audio record volume juicytunes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-17-2010 03:33 PM
"Session must be on an Audio record volume" - Workspace info jojo101 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-19-2007 06:07 PM
"Session must be on an Audio Record volume" - Workspace info DigiTechSupt Pro Tools M-Powered (Mac) 20 03-11-2007 06:23 PM
Audio Record or Playback Volume Error Info jarno 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-12-2006 05:22 PM
need help :workspace audio record volume nicolas paris 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-24-2004 05:51 PM
