Community Terms of Use
Google Search | Search Knowledge Base | Search Avid.com
Find Support | Pro Tools Support Videos | Support FAQ
Software Updates, Drivers, Manuals, Compatibility, Troubleshooting, etc. (Links)
Please post your message once only to the correct forum
Help us Help You - READ THIS Before Posting!
Pro Tools 11
Go Back   Avid Pro Audio Community > Legacy Products > Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win)
Old 05-01-2005, 07:38 PM
sid rosen sid rosen is offline
Default emachine- turn the wifi off!
for anyone else with an emachine 6811 laptop and an mbox, this might help if you already haven't figured it out like i just did: turn off your wifi radio while using pt 6.7 and the buffer overrun errors may very well go away. on another subject, does anyone know how to stop the cpu from running slower when on batter power? mine goes from 2.2 gig to under 1 gig. then the errors come back too.
thanx,
george
Old 05-02-2005, 05:06 AM
Nitronick Nitronick is offline
Default Re: emachine- turn the wifi off!
start/control panel/power options. Change the power theme to always on. The laptop should have seperate settings for both AC and battery use.
Mitchell Benson
Linda Brown and Associates
www.lindabrownandassociates.com
Old 05-02-2005, 06:39 AM
mitchell, thanx, but i've already done that. i've saved a power option as 'pro tools' where nothing ever turns off, and that's all cool, but still when on battery power, if i go thru control panel>system, the clock speed goes way down. i'm thinking it might be a registry hack, which scares me.
thanx again,
george
Old 05-02-2005, 07:18 AM
I haven't looked myself, but you might checkout you BIOS and seeing if there are any power saving features you could shut down there.
Just a guess.
Mitchell Benson
Old 05-02-2005, 04:37 PM
mitchell,
i think you're right. i remember reading a reference somewhere about power savings changes being made in the BIOS. that's one more area i'm sorta scared to get into, but i might give the folks at emachines support a call and see if they could walk me thru it.
thanx again, i'll keep ya posted,
george
Old 05-02-2005, 09:15 PM
Not really that big of a deal. Just make absolutely sure of the changes you make before saving and exiting. Even if you make changes, you can exit without saving, and everything will stay the same as it was before.
Have a look at your manual. It may have a section dealing with BIOS.
Mitchell Benson
Old 05-03-2005, 09:26 PM
mrufino1 mrufino1 is offline
Are you on SP1 or 2? I have a 6805, when I upgraded to SP2 that no longer happened, it always runs at the faster speed. It is a conflict between the 64 bit AMD driver and XP, but SP2 seems to have addressed it. You can also install AMD power now. Check notebookreview.com on their forums, a lot of good emachines answers. Keep in mind f you have an mbox SP2 blue screens it with PT 6.7, I upgraded to 6.9 and no blue screens (I had no choice but to install SP2 when I did a reformat two weeks ago). Hope that helps.
Anyone Using A P5K-E Wifi AP Board For PT? Which BIOS To Use? epu Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) 1 05-15-2010 10:59 AM
WiFi J2sound Avid Live Sound Systems 3 06-10-2009 05:18 PM
Router wifi in FOH kalunga Avid Live Sound Systems 1 11-29-2007 06:41 PM
emachine Bender Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) 3 08-12-2007 05:06 PM
Asus WiFi Rail Jon Rogut Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) 3 02-19-2004 06:45 PM
