Compact Selected
After streaming 24 tracks of 24bit/44.1 audio from a Hard disk recorder into ProTools from a live recording, I would like to REMOVE unwanted audio between songs from the session. The session size is in excess of 50 GB, so in the interest of time and disc space, I would like to do this WITHOUT COPYING OR CREATING ADDITIONAL AUDIO FILES. (Without using 'Consolidate Regions', which creates NEW audio files).
After separating and deleting regions of unwanted audio between songs, doing 'Select unused regions', 'Clear Selected'-> 'REMOVE' from session, I would expect the 'Compact Selected' command to break the existing audio files up so that the remaining audio files match the remaining regions in the session. The 'Compact Selected' command does not appear to do this you might expect... So how can you conform your session audio files to existing regions when 'Compact Selected' does not appear to break up the audio as you might expect. Is there any way to accomplish this without creating addional audio by selecting regions and doing 'Consolidate Regions'? PT HD TDM v6.7 (XP) |
Re: Compact Selected
Wolf.
The proccess you have followed is correct. . But Tools does create new audio files which match your trimmed regions, then deletes the originals. . You might find that there is not enough space left on your drive for this to be done. What exactly is happening on your screen when you try this ? What response does Tools give you ?
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
one thing I was always doing wrong with consolidate, I would select the regions in on the tracks themselves. Consolidate would then do nothing. You need to select the whole files that pertain to the regions on the tracks. Consolidate them, and it will chop them up into the regions on the tracks.
It does seem counter intuitive and I've never liked the way Consolidate works. It took me a while to figure out why sometimes it would work and other times it wouldn't.
Derek Jones Sound Engineer / Producer / Composer Derek Jones Linkedin Megatrax Recording Studios Megatrax Studios Yelp Page A-list Music Artist Page |
"Compact selected" screws up timing 'til reopen? | strider07 | Pro Tools TDM Systems (Mac) | 2 | 12-30-2004 03:03 PM |
Compact selected | Veal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-21-2003 10:12 PM |
Compact Selected Recovery | c0w | General Discussion | 0 | 03-27-2003 09:50 AM |
Strip Silence & Compact selected. | kurt | Pro Tools TDM Systems (Mac) | 9 | 02-11-2003 10:17 AM |
Using 'Compact Selected' before bouncing to disc... | Roy Howell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 01-31-2002 10:26 AM |
