Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 04-26-2005, 03:46 PM
kmt kmt is offline
Default Check CD error rate
Hello to everyone out there!
I've got a question concerning mastering:
What do you think is the best way to ensure that a master CD-R (which shall be sent to
the copy factory) is free of errors (e.g. drop-outs etc.)? Do you know a software which
can do this? My way in the past was to playback the whole CD in my standard CD player. But
this takes up a great deal of time. Perhaps you know a better (faster/more detailed) way to
find errors on a master CD?!?
Greetz
Kai Markus Tegtmeier
Old 04-26-2005, 04:09 PM
bigbubbaj bigbubbaj is offline
Default Re: Check CD error rate
If you burn it using redbook authoring software, I usually burn copies at 1x,4x,8x and the fastest that the burner will do. Send ALL of those to the duplicator.
What are you using to burn the CD's, wavelab or CD architect etc?
5198 Studios
Old 04-26-2005, 04:10 PM
Youo shouldnt have errors on a disc using a program like that, also. You will find that the program will reject the disc rather than burn errors etc.
5198 Studios
Old 04-26-2005, 04:34 PM
Ducky Ducky is offline
I think this is the info your talking about: here
This is high end stuff and most casual and trained ears will never hear it, but in duplication, it can be crucial.
Old 04-26-2005, 04:41 PM
Chris Cavell Chris Cavell is offline
You should always take a listen to the disc before sending it off...even though it takes up to 80 minutes to pull it off.
I (and many other ME's) pretty much stick to plextor drives and the plextools software for quality control error checking.
In order for a cd to remain red book compliant, it must have less than a 220 max BLER (E11+E21+E31), and no E32 errors.
Most mastering engineers apply far more stringent rules than what is considered acceptable by red book standards to their quality control.
Cavell Studios
Old 04-27-2005, 10:07 PM
Sacred Spirit Sacred Spirit is offline
Has anyone ever compared a disk burned by Masterlink ML9600 to see if it meets redbook standards?
MusicXPC 2.8/512
PTLE 6.4 CS6&9
Waves: Platinum(5) & IR1 (5.1)
DigiOO2 Factory
Old 04-28-2005, 06:32 AM
That depends on a lot of factors...namely the medium. It can produce a red book cd...but honestly, the masterlinks converters are pretty horrible and it's SRC is simply dreadful. I'd probably burn with a no-name internal drive comp-usa special before opting to burn with a masterlink.
Cavell Studios
Old 04-29-2005, 03:39 AM
kmt kmt is offline
First, I'd like to thank all of You for these helpful hints.
Normally, I use Wavelab for burning CDs (which uses the
Roxio CD engine, I think). But the Plextor tools are
a very good hint which I'll try out. Nevertheless there
won't be any CDs sent to the duplicator which I haven't listened
completely before.
Greetz from Hamburg
KMT
Old 04-29-2005, 05:40 AM
Wavelab uses it's own engine and set of burner drivers.
Cavell Studios
Problem detected with audio clock. Check your clock source and sample rate. sleeptalken Pro Tools Software (Win) 5 02-26-2014 09:26 AM
Pro Tools 8: Activation code not working/Error: Data Error (cyclic redundancy check) Mattmattmatty Pro Tools Software (Win) 2 05-01-2013 04:26 AM
clock source and sample rate check frcjt Pro Tools 9 6 08-05-2011 04:42 PM
problem detected with audio clock. check that your clock source and sample rate are c angeleda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-05-2010 07:09 PM
Rate Check moosh Tips & Tricks 5 03-05-2000 03:29 PM
