Old 01-27-2005, 02:00 PM
rcourell rcourell is offline
Default Recording with/without Compression and Eq Digi 002
Hi
I was wondering which way do you prefer to record. Im using the Digi 002 and im wondering if i should record vocals and guitar etc with or without commpression and eq. Before when i used to use a Tascam DA88 and a Soundcraft mixing desk, I used to add compression whilst signal was going on to track and a little eq.. however its a little more akward when using the Digi 002 as I have to buss signals etc and also im conncerned about processing on the cpu... I would be interested in which way you prefer to record and if you add compression whilst signal is going to track would or could you give me any nice compression ratios etc
Many many thanks
Ronan in Ireland
Old 01-27-2005, 02:14 PM
Keith Owens Keith Owens is offline
Default Re: Recording with/without Compression and Eq Digi 002
most of the time I get good mic placement, good levels into my pres, and record straight in
soon to be back at it again...
Old 01-27-2005, 02:20 PM
if you wanted to give the artist more eq on the headphone mix how do you achieve it - whilst recording them on the digi 002 mixer setup. thanks
Old 01-27-2005, 02:27 PM
I run the phones through a headphone amp that has EQ
Old 01-27-2005, 02:56 PM
Room24Prod Room24Prod is offline
If all you wanted was to add eq, you can insert an EQ plug-in on the audio track you're recording on and it won't record the EQ. You'd have to set up a bus to actually record compression, eq, etc.
Digi 002R Factory Bundle
P4 2.4 Ghz 1MB Cache
1GB PC3200 Dual-Channel DDR RAM
40GB HDD for OS
250GB HDD for Audio
(2) 17" Monitors
Recording Vox with Compression DonaldM Tips & Tricks 10 02-23-2010 06:47 PM
recording VOX with compression on 7.4 LE flyingaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-26-2009 08:33 AM
Recording with compression (efx) Scorpio253 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 01-21-2009 07:27 PM
recording with compression plugins polf Tips & Tricks 9 11-19-2005 04:35 PM
Recording with compression whayne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-19-2004 06:20 AM
