Old 11-25-2004, 04:16 AM
Oralet Oralet is offline
Default Compatibility: 0S X 10.3.6 and Pro Tools LE 6.4.
Does anybody know if updating to from OS X 10.3.5 to OS X 10.3.6, can make Pro Tools LE 6.4 run again? In other words does 10.3.6 fix the bucks experienced in 10.3.5? - or do I have to upgrade to Pro Tools LE 6.7 to make my system work again?
I'm working on powerbook with MBox.
Oralet
· ProTools LE 8 -
Digi 003 (Rack) Factory
· Mac OS 10.6.5 -
MacBook Pro 2.4 GHz, 4 GB 667 MHz DDR2 SDRAM
Old 11-25-2004, 04:19 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Compatibility: 0S X 10.3.6 and Pro Tools LE 6.
i have heard 10.3.6 is even worse than 10.3.5 and the safe bet is still keep using 10.3.4
Janne
Old 11-25-2004, 05:46 AM
Mip Mip is offline
Default Re: Compatibility: 0S X 10.3.6 and Pro Tools LE 6.4.
Hello Oralet,
don´t update to 10.3.6 it will not work !!!
good luck !
Old 11-25-2004, 05:52 AM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
works fine here.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Old 11-25-2004, 08:31 AM
Do you actually run Pro Tools LE 6.4 with MBox on a Powerbook with OS X 10.3.6.?
Didn't you have problems with OS X 10.3.5.?
Oralet
· ProTools LE 8 -
· Mac OS 10.6.5 -
Old 11-25-2004, 10:19 AM
influenceaudio influenceaudio is offline
I am running 10.3.6 with PT LE 6.4 with absolutely noo problems or crashes.
Imac G5 1.6 1G Ram
MBOX
Event TR8
Old 11-25-2004, 10:40 AM
Cliffy_Boy's Avatar
PTLE 6.7 ( and 6.4), 002R and mBox, dual 2.5 G5, 10.3.6. Internal drives. Solid.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
Old 11-25-2004, 03:47 PM
spicyitaliano spicyitaliano is offline
I just ordered a dual 2.5 ghz G5 a week ago, it's supposed to be in tomorrow. It's coming with 10.3.6, and I (will soon) have 6.4. Cliffy Boy, I sure hope you're right. Because if you aren't, I don't think theres any way I can downgrade if the OSX disc I get is 10.3.6.
I'll keep my fingers crossed.
Old 11-25-2004, 04:43 PM
nedorama nedorama is offline
Dual 2GHz G5, 2.5GB RAM, 10.3.6, no problems with 6.4LE, and now no problems with 6.7cs2.
Regards,
Ned
Monkey Boy Studios
2013 15" MacBook Pro, 16GB RAM, OSX 10.13.2; 512GB SSD System drive, Glyph GT050Q 1.5TB & 2TB FW800 drives
Summit Audio 2BA-221, TLA-50 -->Eleven Rack, Pro Tools 12.8.3
12 Plugins: McDSP, PSP, SoundToys, Izotope, Bomb Factory, AIR PTIEP, AAS, Arturia Collection, IK Amplitube 3, SampleTank 3, BlueCat Audio, Massey DRT, Cyclops, VEP5 Pro, Sonoma WireWorks Drumcore 4
10 Plugins usable again with VEP5: B4
Given Up Hope: URS, NI Pro-53 (lost VST installer)
Old 11-26-2004, 04:05 PM
yOkO yOkO is offline
here are ploblems i have had on 10.3.6 with pt6.4 cs9ed
loose my plugin settings
loose my midi setup
everything fixable, since then all fine.
before cs7 and cs9 when i deleted an audio region, like 3 steps of my history went away.
right now everythings working fine, haven't done lager than 30 minutes sessions.
did anyone does?
so what
pro tools 10 compatibility djecaron16 Pro Tools 10 2 09-06-2013 05:34 PM
Pro Tools 9 and M box compatibility tombh Pro Tools 9 2 11-18-2010 05:40 AM
Pro Tools 8 and Mac G4 compatibility swgerow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-23-2009 10:53 AM
Compatibility from pro tools 7 to 6 ped Pro Tools TDM Systems (Mac) 2 03-28-2006 12:56 PM
M-Box to Pro Tools TDM / HD compatibility ? SportsSounds Post - Surround - Video 1 12-17-2003 08:15 AM
