Old 11-02-2004, 04:55 AM
Zaxxon Zaxxon is offline
Default MBox Monitor levels and white noise on playback
Can someone send me a couple of quick answers for these questions:
1. I’m running the outputs of the Mbox directly into some KRK V6 monitors. How can I control the volume of what I’m monitoring through these speakers?
2. I recorded some keyboard, but when I play it back, there is white noise present. How can I stop this?
Thanks,
Zaxxon
Old 11-03-2004, 08:36 AM
SumOdRsn SumOdRsn is offline
Default Re: MBox Monitor levels and white noise on playback
I can help with the first question. Create a new stereo track and set it to Master Fader. Then you can use that to adjust the output to your monitors. I about killed my ears the first time I opened the demo session. Took me a while to figure it all out.
Old 11-03-2004, 10:41 AM
Icemaster Icemaster is offline
Maybe the white noise what ac hum are the cables you use balanced? And it might be that the keyboard power source from the outlet may be creating a ground loop to the speakers. So first check with the cables then also you could try to get the recorded keyboard signal hotter to improve the Signal to noise ratio if I'm not mistaken. Just wanna help if I can.
~-Icemaster-~
Pentium4 (2.4Ghz)
Windows XP Home Edition (SP2)
80GB HD
1GB Ram
Digi002
Protools 7.0
Mackie HR-824's
mbox: low volume, white noise on playback ashrees 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-16-2005 09:25 PM
MBox Monitor levels and white noise on playback Zaxxon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-01-2004 01:35 PM
White Noise/Static during playback w/Mbox & PT 6.4 Josh Greenberg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-05-2004 05:48 PM
White Noise / distortion on Mac MBox on Playback DJ Nigel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-14-2004 08:25 AM
Playback turns to white noise Mbox/OSX/6.0 Eric R. Fischer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-20-2003 11:13 PM
