Old 10-15-2004, 05:07 AM
urumita urumita is offline
Default Error code -10660
After updating to 6.4cs9 and the 6.4cs6 plugin update I cannot launch a session directly from the finder and there is a dialog that says that the requested operation cannot be performed error code -10660. If I launch PT first it will launch the session from the open session command under the file menu. annoying.
What's more annoying is the infinite spinning color wheel in the middle of playback of sessions made with 6.2.3, all meters freeze (in PT and on the C24) and there is no way to exit the program. I have to shut down the computer manually. if I'm recording I can find the files and import them back into the session but it takes time and doesn't seem like a very professional attribute of computer recording to my clients.
With 6.2.3 I was running OS 10.3.5 with no problems. I didn't expect that with the update I would have problems.
I have a G5 with 2x 2GHz, a 250GB Maxtor SATA, an SNS A/V San, a Magma 64bit 33 MHz 7 slot expansion chassis with HD ACCEL 3, 2 Prism ADA 8, 1 192 I/O. I have tried every combination, if I record or playback from the SAN or the SATA, have the core card in the G5 or the Magma, disconnect the C24 etc...
Any help from digi tech support or someone else who may have had the same problem would be appreciated.
thanks
love and light
Old 10-15-2004, 06:58 AM
bricoleur bricoleur is offline
Default Re: Error code -10660
Sadly you will get little help from digi support if your running an 'unblessed' OS version.
Your error code is going to be a OS error message, not a PT one.
HTH
kind regards,
Michael.
Old 10-15-2004, 09:15 AM
In fact, My computer has started freezing when I'm using MAIL too. It might be the computer and not any program conflict at all. Does any one have any ideas. Short computer history; recently changed the logic board because of a faulty ethernet port, came back and worked fine untill I did the update.
tragic notes; To find this problem I will have to reinstall 10.3 and update many times to 10.3.4 and maybe reinstall PT and other programs that have their prefs locked to 10.3.5? That was actually a question. Or will DD come up with a 10.3.5 compatible version soon? I would rather download one fix than start the retroinstallation process. Will 6.7 be compatible with 10.3.5 on a 2x2GHz first edition G5?
As of now if I start a session in 6.4 it goes ok. It's the older converted sessions that are having problems. i'm looking for a ray of light that tells me that within a week or so I'll have a solution that won't cost me 16 hours downtime.
hanks again
love and light
Old 10-15-2004, 11:57 AM
spigots spigots is offline
Shot in the dark
http://www.macosxhints.com/article.p...40607161946135
Pro Tools 8: Activation code not working/Error: Data Error (cyclic redundancy check) Mattmattmatty Windows 2 05-01-2013 04:26 AM
Code 32 error and error # 7400. wcolombo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-16-2010 03:48 PM
eroor -10660 atill161 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-21-2004 07:21 AM
DAE -225 Error Code Don't Panic Digidesign Hardware & Software 4 06-21-2003 09:27 AM
SDII bus error (error code 1) trilogy Digidesign Hardware & Software 4 10-11-2001 08:36 AM
