Old 06-10-2004, 06:29 PM
Matt_G Matt_G is offline
Default Error Playing a Session Folder That Has Been Moved
Have any of you found this error or know of a work around? In Protools 6.X.X doesn't matter which version, if I have finished mixing a session & then move it into another folder (same drive) & I go to open it & play it I can see all the audio files but it will not play giving me a DAE error. I have tried re-assigning the audio file paths in the workspace window but nothing? Is this a commonly known error? Is there a simple fix? The only way I can get the session to work again is by moving it back to it's originally location. This scares me a bit because what if I back it up to DVD & restore it in the future to a different location or drive? Will it play? I am using Protools 6.4 with G4 867 & HD2. OSX 10.3.3. 1.2G RAM
Mastering Engineer
www.matthewgraymastering.com
Brisbane Australia
Old 06-10-2004, 07:15 PM
DigiTechSupt's Avatar
Default Re: Error Playing a Session Folder That Has Been Moved
What is the text of the error message that you are receiving?
Thanks
Digidesign Technical Support
Avid Audio Tech Support
Support FAQ
Old 06-11-2004, 10:21 PM
Thanks
I get a DAE Error -9035 everytime I hit play. Any ideas?
Thanks Matt
Mastering Engineer
Brisbane Australia
Old 06-14-2004, 07:33 PM
Bump.. Digi?
Mastering Engineer
Brisbane Australia
Old 06-14-2004, 07:59 PM
There is a 31-character limit for all Pro Tools file names. Trying to open Pro Tools files with names longer than 31 characters
will result in a DAE error –9035.
There is a 31-character limit for all Pro Tools session folder names. Trying to play a session whose parent folder is longer than 31 characters will result in a DAE error –9035.
I have also seen this when a drive is almost full or very fragmented. Try saving the session to a different drive that is less fragmented. To do this, go in Pro Tools to File>Save Session Copy In and save a copy of the session. Be sure to put a check in the box for "All Audio Files" in the "Items to Copy" section.
Thanks,
Digidesign Tech Support
Support FAQ
Old 06-15-2004, 12:14 AM
Ok thanks, that makes sense as the folder I put the session into did have a long charachter name. Is this quirky little bug going to be addressed in the next point release?
Mastering Engineer
Brisbane Australia
Plug-in folder moved colourednoise Windows 4 04-01-2013 06:47 PM
error -9073 when playing back recorded session folder docleagh macOS 3 12-31-2012 11:23 AM
-9131 error on playing session from LE in HD... ProToolsIgniter Pro Tools TDM Systems (Mac) 2 07-18-2006 02:22 PM
Moved sessions to a folder, files can't be found BRAVO-STUDIO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-01-2004 01:09 PM
moved my session onto a faster drive, but PTLE is still playing the old audio files heartparts 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-09-2002 10:09 PM
